Front Brake Question
Being new to my Harley...(and being an avid road bicycle rider/racer where we need to have the wheelsclear the brake pads)...I'm curious...if I lift the bike for servicing/cleaning...should the front wheel turn free or do the pads rub on the rotor? Minerub...should they be touching/rubbing onthe rotor when riding?
Might be stupidquestions...and...yes...there are such things as stupid questions...but...oh well...
Thanks for any info. in advance!
[IMG]local://upfiles/54656/F9709623A71342098B172133C8D4116A.jpg[/IMG]
RE: Front Brake Question
They do drag a bit, especially when you have fairly new pads. You can try shimming the caliper slightly (read very thin washers between the caliper and mounting tabs) to center the rotor between the pads a little better.
You could also upgrade to floating rotors which will also help.
