When you buy rain gear do you....
Old 04-11-2008, 01:38 PM
gunnar's Avatar
gunnar
gunnar is offline
Default When you buy rain gear do you....
Buy the gear a size or twolarger so it willfit over your leathers or do you take your leathers off when wearing your gear?
Old 04-11-2008, 01:43 PM
liltrk's Avatar
liltrk
liltrk is offline
Default RE: When you buy rain gear do you....
Rain gear is hot enough without having leather underneath. Whew!
Old 04-11-2008, 01:47 PM
wdg's Avatar
wdg
wdg is offline
big enough to fit over leathers
Old 04-11-2008, 01:50 PM
anubisss's Avatar
anubisss
anubisss is offline
It all depends on what happens if it starts to rain and where you are. Changing on the side of the road is enough of a pita without taking off a layer.
RDM's Avatar
RDM
RDM is offline
Some rain gear is made larger than a normal size so it will fit over riding gear. Make sure to check that out before buying a larger size than you would normally buy.
Old 04-11-2008, 01:52 PM
rhbuilds's Avatar
rhbuilds
rhbuilds is offline
frogg toggs are great.
Old 04-11-2008, 02:13 PM
Unome's Avatar
Unome
Unome is offline
ORIGINAL: wdg
+1
Every time you get caught in rain, it might not be 75 degrees and you not wearing leathers. I've even worn rain suit over leathers in winter to help with wind.
Old 04-11-2008, 02:15 PM
drfeelgood's Avatar
drfeelgood
drfeelgood is offline
A size larger to fit over leather.
Old 04-11-2008, 02:20 PM
Peppa1's Avatar
Peppa1
Peppa1 is offline
ORIGINAL: RDM
I would suggest that you try on the rain suits prior to purchase to see how they fit as like other clothing articles, helmets etc. different manufacturers sizes aren't always the same. Ordering these types of things over the internet are hard.
Old 04-11-2008, 02:47 PM
ToadsUltra07's Avatar
ToadsUltra07
ToadsUltra07 is offline
No, I have never purchased rain gear to fit over my Leathers. It is HOT enough just wearing the rain gear. And I have the set that is suppose to allow some breathing in them so there not so hot while wearing them.
Like Peppa1 said, "Try on the rain suits prior to purchase to see how they fit as like other clothing articles, helmets etc. different manufacturers sizes aren't always the same.
I purchased a size over what I would normally wear. Had to wait for a week for them to come in. Size 5XL just is not on the shelf. This is after I tried on the 4xl, well, it was just too short around the chest and arm length. Ok, Ok, also around the belly location too, just wouldnt zip up either. LMAO..
ToadsUltra07
Quick Reply: When you buy rain gear do you....
