GPS WIRING
RE: GPS WIRING
Yep, go to Radio Shack and buy a quick disconnect wire kit, it looks like the Battery tender quick connect. Cut the Garmin provided 12V/2amp fused wire harness and solder the quick connect wires to it, use shrink wrap,and then connect to any 12 V source, such as accessory plug under seat in fron of the battery or the 12v not being used in the light housing. Good luck.
RE: GPS WIRING
When I got my UC, the dealer had installed a Battery Tender wiring harness. Can the shown connector be used to connect to the Battery Tender harness for power? I would assume so and also it could be used to power an electric vest. I realize the wiring for the GPS would have to be routed under the gas tank; but I think it is a better solution than using the accessory plug.
RE: GPS WIRING
ORIGINAL: Moby
Here you can see the connectors that you will find taped to the headlamp harness under the fairing
[IMG]local://upfiles/13641/204050ADCD754D27BB516F36BF7CCA61.jpg[/IMG]
Here you see the in-line two pole flat connectors up by the clutch cable
[IMG]local://upfiles/13641/21B017ED7FA647E9934F0F98F714D4B2.jpg[/IMG]
Here you see the extra wire looped and zip tied to the fairing bracket
[IMG]local://upfiles/13641/CB81387FC78744179875D673A01F5C82.jpg[/IMG]
Here you see my 105th splash screen
[IMG]local://upfiles/13641/08DD47F6BB654807823D6CD6CAC48BFD.jpg[/IMG]
RE: GPS WIRING
I think I understand what you are saying; but why not just use an auto power setup? This is a plug for the cigaret burner and a connector for the GPS that the GPS manufacturer sells. The Harley owner manual indicates not to use the cigaret power adaptor for other "appliances". I don't understand why. But has anyone else had problems with using the stock cigaret hole for other attachments? I would rather a more permanent solution; but am not against using the stock cigaret plug.
RE: GPS WIRING
ORIGINAL: Moby
Thanks for the idea; but I don't quite follow it. If I understand what you are saying, there is an adaptor under the faring; but how do you get that connected to something on the handlebar? How do the wires come out of the inner faring?
[IMG]local://upfiles/13641/C84F3CF519BF49DEB866835EA60C024B.jpg[/IMG]
RE: GPS WIRING
ORIGINAL: Moby
Gart
