Engine modifications/ longevity
Been following the board for awhile now, did a stage 1 on the bike after reading reviews and comments from everyone. Pleased with the performance, but sometimesthere's an "itch" to have a little more. Obviouslya lotof the members have put some big time money in modifying their powerplants, and in resulting posts have seen a few comments that they're not so concerned with how long it lasts (within reason), but more so how much fun they have with it.
Is it a given that modifying the output of the engine that there's a direct correlation between how long it stays "healthy"? Might sound like a stupid question, but got a lot of miles out of my old EVO that was basically stock. Is there a certain point in the hop-up process where you realize engine life could be shortened? Or is it just a matter of how well it's done?
John
2007 FLHTC
TMAX w/ AT, Fatcats, ANBS
John
2007 FLHTC
RE: Engine modifications/ longevity
If it is built, and tuned properly, a performance build will last as long as a stock engine unless you abuse the hell outta it do to having more power on tap. There is a point wher you start to lose longevity, but it is way beyond what most here on the forum have done.
From my conversations with several engine builders a modified engine can actually be more reliable than a stock engine considering it is done properly. Anything up to around 10:1 compression and .600 lift cams should be very reliable and get up to around 100,000 miles before requiring a rebuild of some sort. Once you get into the 10.5:1 + compression the longevity of the engine may be reduced abit just beause the higher comp engines are a bit harder on the rings andvalve train.
That makes complete sense Pingman, attention to detail has got to be a plus when putting an engine together. That's making my decision to modify much more feasible, in my mind the package is the only way to go. I'm not astute enough to say what will work and what won't, definitely don't want to plunk some hard earned money down on mix/ match pieces and regret it. I'm in the process of speaking to a builder about a package job, just wanted to sort the reality of modifications and what I can expect for reliability. Thanks for the help.
desertwolf
2014-2023 Touring Models
08-21-2018 12:38 PM
