brake pads
RE: brake pads
I put a set of Lyndall Z+ pads on the rear of mine a week ago and got rid of the constant squealing. Will be replacing the front pads this weekend in the hopes of reducing the drag on the front wheel.....my front brakes currently drag so bad its hard to push it around in the garage and it is of course "normal" as far as the dealership is concerned....decided not to screw around anymore and just replace the pads myself..
RE: brake pads
ORIGINAL: Windup08
Here is a Piston Cleaning Procedure to try first or during the new pad install.
Troubleshooting brake drag:
Insufficient brake lever play.
Caliper piston worn or damaged.
Excessive brake fluid in reservoir.
HDMIKETN64
06-05-2017 06:01 AM
fltrxcrzy
2014-2023 Touring Models
10-01-2015 01:55 PM
