lost of MPG
lost of MPG
I've got an 07 ultra, I put tru duals on, SERT,SE air, I went from 40mpg around Kansas to 34mpg. I've got lots of power, but I like mpg also. Should I have the girl re-tuned or is theresomething else that should or could be doneOn the re-tune. Will I need the pay the Dino cost again. What ajustments can be made at the lowest cost. I'm about out of myallowance.
Once A Marine , Always A Marine
RE: lost of MPG
Have you checked the plugs for color? See if it is really running too rich or not. How about right wrist syndrome? Have you been getting on it more since the mods? I have the same situation with my 08 Ultra after the stage-1 upgrades....last weekend I ran another tank of gas through riding real conservative to make sure it wasn't my riding style. Milage is still really low and plugs look like crap, so I'm going to try get mine back on the dyno, will likely be calling the dealership today.
RE: lost of MPG
When did you have the stage-1 and dyno tune done? I had mine done last fall (October) and the dealership has agreed to re-tune it at no additional cost to me. I would try talk to them and see if they will work with you. Sounds like your's is doing about the same as mine....I was getting mid-40s before the upgrade and very low 30s now....there is no reason a stage-1 upgrade should drop milage that much.
RE: lost of MPG
I had the same problem after I installed a Doherty PowerPacc and Terminal Velocity 11 already had the Supertrapp's the mpg tanked bad, WTF the TV11 should increase mpg from what I've read, ran 4 tanks of gas still bad, I changed plugs Autolite 4164, mpg came right back up to mid 40's.
RE: lost of MPG
AS SOON AS YOU INSTALLED A FUEL "MANAGEMENT" SYSTEM YOUR MPG PROBLEM STARTED.. ANY FUEL PROGRAM WITH DECREASE YOUR MILEAGE. YOUR MOTOR IS AN "AIR PUMP".. MORE AIR OUT (EXHAUST) MEANS MORE AIR IN. MORE AIR IN MEANS MORE FUEL IN. ITS THAT SIMPLE ! WANT BETTER MILEAGE .. GO BACK TO BONE STOCK!
RE: lost of MPG
ORIGINAL: NICK56
RE: lost of MPG
ORIGINAL: SSJ
Has anyone else seen this happen (swapping plugs and seeing an increase in MPG's)?
RE: lost of MPG
ORIGINAL: Arizona
I find this very interesting. So your mileage went back up significantly just swapping plugs? Is the Autolite 4164 the plug for all the TC88's?
Has anyone else seen this happen (swapping plugs and seeing an increase in MPG's?
