MP3s on Disc
Old 11-16-2009 | 02:00 AM
Jukebox's Avatar
Jukebox
Make sure you download it as a DATA CD,that's all I had to do. I get about 150 songs to a CD and it plays every song just fine. I used Limewire(for free) to download the songs to windows media,and I used the windows media to find info for all the music so they are all tagged with the proper title and artist.
Old 11-16-2009 | 07:42 AM
santajim's Avatar
santajim
I had issues when I first started burning, the trick is you have to burn the disc as a data disc.
Old 11-16-2009 | 08:33 AM
NHSPMCU's Avatar
NHSPMCU
Some times it works, sometimes it says "bad disk" I use same format as you do. When it says "bad disk" I eject it out and put it back in and it will work fine. I don't get it!
Old 11-16-2009 | 08:40 AM
skratch's Avatar
skratch
here is a freeware program that i use to make mp3s, http://www.exactaudiocopy.de/en/inde...rces/download/
because its freeware, the documentation for it is a little sparse, go here to configure:
http://www.teqnilogik.com/tutorials/eac.shtml
remember, the higher the quality, the more space that each song will take up. being on a bike, with the wind noise and exhaust noise, you can go with a lower setting on quality for more songs on the disk.
and as has been noted before, burn as a data disk, not a music disk, as some programs will reconvert the mp3 back to native format.
Old 11-16-2009 | 08:47 AM
bdp's Avatar
bdp
I've made a disc with about 100 songs and it works fine, that is until I remove it. Put the same disc in later and get a disc error. Throw it in the trash, burn another and all is well.
This has happened on 3 out of the 6 disc I've made, maybe its the format or the Maxell disc I'm using.
Old 11-16-2009 | 08:50 AM
dirtdobber's Avatar
dirtdobber
I use http://www.mediamonkey.com/ with great results
In God we Trust
dd
Old 11-16-2009 | 01:30 PM
Jukebox's Avatar
Jukebox
I still don't get it,I have never had one single problem with any of the CD's I have ever made for the bike radio. Knock on wood I guess.
Old 11-16-2009 | 02:49 PM
Skip's Avatar
Skip
Being technically challenged, will these methods also work to copy by CD's to a USB memory stick? I have a Sony radio/player on my EGS which plays CDs/Ipods/USBs.
Old 11-16-2009 | 03:05 PM
FLHTCUI05's Avatar
FLHTCUI05
I have several disc's that will play one time but not the next. Good Luck!!!
Old 11-17-2009 | 06:51 PM
stroker23's Avatar
stroker23
Totally blown away with all this info. Is there any way to isolate this thread to your desktop or elsewhere that will update and make it available upon demand? I have an IMAC and never knew it was this diverse?
Unbeliveable
C908
12-31-2012 03:35 PM
bberck
08-07-2012 03:11 PM
BuckeyeRider
03-23-2010 12:42 PM
shekmark
08-18-2008 10:11 AM
bigbean78
07-23-2007 12:57 AM
Quick Reply: MP3s on Disc
