08 FLHR Tach Install - help
Trying to install a tach on my 2008 Roadking (FLHR) The instructions say I have to remove the secondary lock on a fuse block so I can insert a terminal for the power source. I have the manual and have read closely the procedure for prying out the secondary lock but I don’t seem to get it – I’m also afraid to break the orange plastic lock. Is there a trick to this or something I’m not seeing?
Also there is not supposed to be a fuse in this “P&A IGN” but my bike has a 15Amp fuse in there – with no mating wire feeding the circuit - ??
Finally I think once I figure out how to get the secondary lock out I can install the terminal without actually removing the fuse block – is this part of the problem.
This has got me greatly annoyed so any advice would be much appreciated.[:@]
THANKS
THANKS
block, davidson, flhr, fuse, harley, install, installing, instructions, locks, secondary, tach, tachometer
