Click? won't start ****ITS ALIVE****
Old 04-07-2008, 10:18 PM
choochoo's Avatar
choochoo
choochoo is offline
Default RE: Click? won't start
One click and one click only.
Starter is stuck in engaged position or a bad starter or loose connection at the starter.
starter relay, solenoid and starer all ground via the starter mounting bolts.
what is the voltage on the gauge!
what is the voltage when you push the start button?
I didn't mean spin it.
Put bike on jack, put in gear then with force turn rear wheel forward and back.
make the tranny move. If solenoid stuck in the drive position, hard rocking will
tend to release it.
But if not locked then it is definitely a electrical connection.
Old 04-07-2008, 10:27 PM
dawg's Avatar
dawg
dawg is offline
Received 3,246 Likes on 1,852 Posts
ORIGINAL: choochoo
One click and one click only. YES
Starter is stuck in engaged position or a bad starter or loose connection at the starter. All connections checked and tight
what is the voltage on the gauge! Volt guage says 11
what is the voltage when you push the start button? doesn't move one way or the other
tend to release it. That's what I did
Nellybelle's Avatar
Nellybelle
Nellybelle is offline
I had similar problem. Mine was loose bolt on starter not making good ground. That what the dealer said.
Old 04-07-2008, 11:04 PM
rysess20's Avatar
rysess20
rysess20 is offline
Prob going to get hammered for this one but did you try a couple of taps on the starter with a hammer?? Gently of course.
Old 04-08-2008, 02:24 AM
RangeRat's Avatar
RangeRat
RangeRat is offline
You might just use a jumper wire to work your way down from the output of the relay to where thesmall wire is connected on the soleniod. Might just still bean open somewhere between +12V and the solenoid even after the relay closes (bad relay contact or plug connection somewhere).
Careful dawg - if there really is an open somewhere then the solenoid and starter will work just fine as soon as you jumper past the bad spot so make sure you're in neutral. I whsh you had one of those cheap Radio Shack multimeters - would be safer.
Old 04-08-2008, 07:45 AM
dawg's Avatar
dawg
dawg is offline
Default RE: Click? won't start ****ITS ALIVE****
Even though all connections were tight and double checked for tightness, I took everything apart and then rehooked it all up and viola! fired right up. Was in a hurry this a.m. prior to running daughter to school and started out the wrong way....attempted taking apart the starter connection before unhooking the battery...DOH! after the spark show I damn near welded my wrench to the rear cylinder
Old 04-08-2008, 09:24 AM
RangeRat's Avatar
RangeRat
RangeRat is offline
[sm=biker2.gif]
Old 04-08-2008, 09:38 AM
Beemervet's Avatar
Beemervet
Beemervet is offline
It should always be that simple.............
Old 04-08-2008, 09:53 PM
Dalton's Avatar
Dalton
Dalton is offline
ORIGINAL: dawg
I can just picture the panic when the sparks started! LMFAO (been there, done that[:'(])
Glad you got it fixed!
Old 04-08-2008, 09:56 PM
rsofa's Avatar
rsofa
rsofa is offline
Glad you have it running again Dawg!!! Dalton told me he thought you were a certified welder!!! !!
Chris1957
Engine Mechanical Topics
04-24-2016 01:54 AM
caclark
General Topics/Tech Tips
06-25-2014 11:39 AM
jm1211
08-11-2011 08:57 PM
Krakanator
08-18-2009 05:03 PM
MITYBAGGER06
05-27-2008 01:30 PM
Quick Reply: Click? won't start ****ITS ALIVE****
