Gas Mileage with a 124" Hotrod Bagger
04-07-2008, 02:35 PM
Well...yesterday I took a little jaunt up to a local swap meet and measured my gas mileage on the way up. At 100 miles I refilled the tank and it used approximately 2.68 gallons for the ride up. That's an estimated37.31 miles per gallon with a hotrodded 124" bagger running with a Tmax and a big inch map. I'm fairly impressed given that i'm agressive on the throttle and still manage that kinda mileage.
[sm=bounceybounce.gif]Now for the cost of Gas = .14 cents per mile. Ouch!
04-07-2008, 02:39 PM
RE: Gas Mileage with a 124" Hotrod Bagger
bout the same as mine....glad youre havin a blast
That's a perfect example.... even with the BIGger motors, when properly tuned, 40(+) mpg should be avg....
I've been getting roughly the same on my 120", even riding 2up. A lot of it has to do with how aggressive one twists the wick though...
04-07-2008, 02:47 PM
Something is wrong with my bike. I'm getting about 30 MPG...I need help.
04-07-2008, 02:54 PM
look at the tables in the crusing range and back some fuel out....like 2500-3200 rpm at 5-15% throttle
I don't think I'm anywhere close to 40mpg, more likely 35mpg---I'll do a scientific study Wed or Thursday.
04-07-2008, 03:19 PM
Quote:
ORIGINAL: lkr0
Lyn -> You don't count! The 40mpg rule applies to "normal" riding! [8D]
Rod, Bryan is right... If you have any questions give John a holler or I might be able to help ya too.
04-07-2008, 03:23 PM
I got 43mpg on my 113" last I checked good mpg is doable on a bigger motor and I think the pro tuner helps a lot on mine. But that seems good on a 124" for sure.
04-07-2008, 03:24 PM
What makes you think Rod's problem is any different than Lyn's?
Zach
04-07-2008, 03:33 PM
Quote:
ORIGINAL: Biggzed
Zach
ummmm..... [sm=confused06.gif]
Paint job.... yea, that's it!
