*&^*$#% Ignition Lock Broke!
Maybe someone can help me out here. Today, I went for a nice ride on my '07 Ultra and noticed on 2 occasions that my ignition "puck" seems to be popping out. After I get the bike back to my garage, I pushed the puck back in and it locked in the down position. With or without the key, it will not spring back up. To make matters even worse, it is now in the locked position (even though my forks are not locked) and I cant even turn it to On so I can get it to the stealership. Something is just jammed down in the mechanism.
After digging through the service manual and searching the posts online about how to remove the part, I tried that for quite a while to no avail.
Anybody else ever had this problem? At this point, it looks as if my only option is to get it towed into the stealer tomorrow for them to look at it.
Thanks everyone. If nothing else, the venting helped.
Mark
Mark
RE: *&^*$#% Ignition Lock Broke!
Unfortuntely, yes. Did it for at least an hour with no luck. At first the button would push in, but now, it seems as if that is jammed too. It's just a bizarre situation all the way around. I was pulling my hair out, so I finally just had to step away. Called HOG to make sure that they would be able to tow it tomorrow if necessary.
Mark
Mark
ORIGINAL: dawg
Have you tried pushing in the tab on the bottom
I had a simularproblem with my 06. The pin on the botton of the lock assembly broke off. This caused the head to lock completely, unable to unlock it. Had the bike down for 4 days (Holiday WeekEnd) before they picked it up and repaired it. There was a recall on the locking assembly for my '06' don't know if this is your problem, but you will want to have it looked at.It could become a dangerous situation if you are riding it .
William[:'(]
William[:'(]
Yeah. No doubt at all that the problem will get addressed tomorrow. I just considered myself extremely lucky to have gotten it to my garage before it locked! With my luck, I could have been stranded in some parking lot somewhere.
Mark
Mark
ORIGINAL: winham79
I had a simular problem with my 06. The pin on the botton of the lock assembly broke off. This caused the head to lock completely, unable to unlock it. Had the bike down for 4 days (Holiday WeekEnd) before they picked it up and repaired it. There was a recall on the locking assembly for my '06' don't know if this is your problem, but you will want to have it looked at. It could become a dangerous situation if you are riding it .
William [:'(]
William [:'(]
Yep. She's still under warranty and my HOG membership will take care of the towing. Im more concerned with the tow truck drivers ability to get her there in one piece without damaging a brand new paint job!
Mark
Mark
ORIGINAL: fireglider
Sorry about your misfortune. Shouldn't your 07 still be under warranty? I know that doesn't get your bike to the dealer though.
