DID I MESS UP??????
Old 04-05-2008 | 03:41 PM
mrsr71's Avatar
mrsr71
Default RE: DID I MESS UP??????
Put a stick of this in the oil filler. Light the fuse & plug you ears. That should take care of it.
Old 04-05-2008 | 03:44 PM
son7771's Avatar
son7771
That there is some funny STUFF!!!! If this is true you need a sign!!!!
Old 04-05-2008 | 03:54 PM
KrustyNutz's Avatar
KrustyNutz
I think I tweaked something. I'm going to hook up my laptop to the ECM and see if I can't get a code to spit out. Maybe that will help isolate the problem. Either that or I'm going to blow the load out ofmy pipe, whatever it is!. I'm so mad![:@] I use to put Marvel Mystery oil in my vehicles all the time I figured this was just like it. guess not.
Old 04-05-2008 | 03:56 PM
1flhtk4me's Avatar
1flhtk4me
The best thing you can do is pour 4 cups of muriatic acid in the hole where the oil goes.This will disolve the Never Seize.You have run the engine at5200 RPM for 15 minutes,this will dislodge the Never Seize from the piston ring grooves.
Good luck.
Old 04-05-2008 | 04:01 PM
IronLegend's Avatar
IronLegend
I'm laugh'in so hard I'm almostpiss'n myself at all this!
Old 04-05-2008 | 04:13 PM
KrustyNutz's Avatar
KrustyNutz
I can't getmy nut off!! I've been pulling forwards and backwards as hard as I can and my nut is stuck! Maybe I should just sell this piece![:@] 1FLHTR4ME, how can I get some muriatic acid? Does the auto parts store sell this stuff?
Old 04-05-2008 | 04:17 PM
mrsr71's Avatar
mrsr71
ORIGINAL: KrustyNutz
On a serious note, you should probably use some ENGINE SCRUB.
Is the inside of your motor dirty? Most likely! Some people will tell you the only way to clean your motor is to tear it down and rebuild it. This is no good!!! KaleCoAuto internals cleaner is a special combination of iron, graphite, and copper shrapnel of assorted sizes that work to sand and polish the inside of your motor! Add 2oz per quart of oil in your car. New engine clean shrapnel should be used at every oil change! Bottle includes pouring mechanism. Comes in 16oz packages. Do not injest. Contact a physician immediately if injested, do not induce vomiting.
Old 04-05-2008 | 04:18 PM
son7771's Avatar
son7771
This is so much better then the posts on thesnowmobile site i frequent in winter!!!! LOL
Old 04-05-2008 | 04:19 PM
ultraman08's Avatar
ultraman08
Must be gay.
Old 04-05-2008 | 04:27 PM
dropone's Avatar
dropone
[sm=laughat.gif]
Quick Reply: DID I MESS UP??????
