Your Tires and Mileage
RE: Your Tires and Mileage
From what I've seen so far, the OEM Dunlops are the clear winner for mileage. I have 13,500 on the rear so far, and it looks like it will go at least another 1500 or so. It handles kind of crappy though, because it is worn off in the middle and the shoulders are less round than new. If that is a concern, then it should have been replaced around 8-9000 miles.
replaced my rear dunlop @9,000 for the simple reason it felt abit squirrly on wet roads,could have seen more mileage,i've always been one to replace both front and rear together for peice of mind,front had plenty of tread left,but nothing better than two new sneakers at once,they ride nice
ORIGINAL: goodbirds
Run a little less pressure in the rear tire to start off with,then go up to normal pressure as you get miles on the tire. This will help with the middle wearing out first.
Go easy on the rear brake. The rear brake tears the rubber off real quick.
If you put on a new tire on in summer and do a few 500 mile rides the high tire tempature cures the rubber.
I switched to metzler ME880s and got 11,000 miles on the rear before I changed it, and it still had some life left on the thread. I don't take chances with tires, so I change them when I start losing confidence in them, or when I am about to take a long trip. I wouldn't like to go looking for tires when out on a trip.
