TOURING BIKE BRAKE PADS
Old 02-09-2006 | 12:11 AM
Danester's Avatar
Danester
Default TOURING BIKE BRAKE PADS
Okay - need to hear from fellow tour bike riders on this - -I have 11,400 miles on the clock on my 05 FLHTI- - the dealer said my rear brake pads have 70% remaining - - I'm kinda skeptical, because I heard of a general rule of thumb "replace every 10K" - - anyone get that many miles outta stock pads? Just curious - -Thanks..
Old 02-09-2006 | 12:19 AM
MACK's Avatar
MACK
Default RE: TOURING BIKE BRAKE PADS
I got 17k plus out of mine but I use my gears a lot and am not to heavy a user of the back.
Old 02-09-2006 | 02:05 AM
Tom's Avatar
Tom
6th Gear
Got 26K on mine right now and it's due. Take the right bag off to get to the brake pad, use a plastic ruler and if the friction material is.04 inch thick or less replace. The same is true for the front pads - be sure to replace on both on the front at the same time.
Old 02-09-2006 | 02:13 AM
Inforit's Avatar
Inforit
I am a heavy rear brake user. Mine wore out at 10K to the bone. Had to replace my rotors because of it. I guess depends on how you use your brakes.
Old 02-09-2006 | 10:41 AM
CHEYENNE's Avatar
CHEYENNE
If you look down thru the side of your pads there should be a wear groove that tells you when you need new pads installed. If you see a groove you are good to go, if you don't..Change ASAP!
Old 02-09-2006 | 11:02 AM
gsparesa's Avatar
gsparesa
I don’t wait for my brakes to need replacing. My general rule of thumb, “Replace brakes every time I replace a tire.”
Old 02-10-2006 | 07:04 PM
Danester's Avatar
Danester
Thanks for the replies!
Old 02-11-2006 | 08:45 AM
spartns's Avatar
spartns
I changed the rear at 15k. The fronts are still good at 19k.
Old 02-11-2006 | 10:35 AM
CHEYENNE's Avatar
CHEYENNE
That's surprising as you do most of your braking with the front.. or well most people do anyways.
Old 02-11-2006 | 10:51 AM
Fergusonic's Avatar
Fergusonic
I thought I read somewhere many moons ago that Front and Rear Brakes should be applied equally (depending upon situaltions such as sand on road/cornering). That's how I try to apply mine. So if that is the recommended application of brakes; doesn't it stand to reason that my pads should wear out close to the same time?
Quick Reply: TOURING BIKE BRAKE PADS
