Chrome Switch Cap Kit
Old 04-04-2008 | 07:19 AM
rath8985's Avatar
rath8985
Stage II
Default Chrome Switch Cap Kit
i bought this kit for my 1998 flhtcui...what a nightmare...trying to install the switches is a real pain in the a**..anyone got any ideas as to make it easier..should you take the switch housing apart somehow?
Old 04-04-2008 | 07:45 AM
dawg's Avatar
dawg
Default RE: Chrome Switch Cap Kit
ORIGINAL: rath8985
Ya kinda have to take the housings apart! Can't be done without taking them apart. Just go slow, it can be a PITA and many folks break one of the caps upon install so be careful
Old 04-04-2008 | 08:14 AM
Harleypingman's Avatar
Harleypingman
A very small flat-bladed screwdriver and magnetic tipped phillips head screwdriver make the job easier. Each cap has a cogged/geared side and plain side. The small blade is used to pry the cogged side off the switch. The magnetic-tipped Phillips is for removing and installing the small screws that secure the wires and switches inside the housings.
Yeah, the housings come apart and the switches are removed from the housings. Almost as important as the tools is attitude. Don't rush or you will likely break a cap which will then need a replacement which will requirea trip to the HD store for a replacement while the bike remains apart and unrideable.
On reassembly, be extra careful to route the wires out of the housing and along the recess in the handlebars--it's very easy to pinch a wire when reassembling the switch housings causing a short circuit--then you can really get p-o'ed and wonder what you were thinking about to even bother with the project.
Old 04-04-2008 | 08:17 AM
FLHT's Avatar
FLHT
It is a PITA. You have to pull the housings apart. And if you heat the caps up a bit with a hair dryer it makes them a little more flexible and wont crack as easy.
Old 04-04-2008 | 09:02 AM
stro1965's Avatar
stro1965
Good luck! I did mine a week or two ago and don't want to do another set anytime soon!!
CHGO5OH
08-21-2013 10:54 AM
Govno
02-20-2012 08:59 PM
Kbore
01-24-2009 01:30 AM
cannejos
01-19-2009 09:55 PM
Alien Spyder
04-29-2006 01:45 PM
Quick Reply: Chrome Switch Cap Kit
