Drive by wire?
Old 04-01-2008 | 05:49 PM
bikerdad5's Avatar
bikerdad5
Default Drive by wire?
I do not think that drive by wire is a good idea for bikes, too many problems with the auto side of this idea. I work for a GM dealership andthey are so picky about working smoothly let alone able to have any manual shut off in case of failure..
Old 04-01-2008 | 05:55 PM
Terry TK's Avatar
Terry TK
Big Kahuna HDF Member
Default RE: Drive by wire?
Do you have any experience with the DBW on motorcycles? Other than a couple complaining of a slight delay (which I understand had a fix) I haven't read or heard of any other problems.
Old 04-01-2008 | 06:05 PM
bikerdad5's Avatar
bikerdad5
Have heard of several accidents and even a death from bike going wide open on its own. Hear say no hard evidence.
biz44's Avatar
biz44
ORIGINAL: Terry1955
What exactly have you heard about the fix for the delay in throttle response? I haven't actually felt it on my bike, but a good friens with a 08' says he has felt it pulling away from stops and such.
Old 04-01-2008 | 06:12 PM
2005UltraNC's Avatar
2005UltraNC
Dealer mentioned issues with throttle getting "stuck" off idle - i.e. revs high at idle. Agree, don't think this a good idea - IMO.
Old 04-01-2008 | 06:16 PM
Terry TK's Avatar
Terry TK
I can't remember what the fix was. I read it here on the forum.
ORIGINAL: biz44
ORIGINAL: Terry1955
Old 04-01-2008 | 06:28 PM
UltraKla$$ic's Avatar
UltraKla$$ic
ORIGINAL: Terry1955
ORIGINAL: biz44
ORIGINAL: Terry1955
I think Gutman(HD Dealership owner that frequents here at hdforums) mentioned an ECM update to combat the Die By Wire phenomenon.
Old 04-01-2008 | 06:34 PM
Jager's Avatar
Jager
No issues on mine. I like it!
Old 04-01-2008 | 06:43 PM
djhrln's Avatar
djhrln
Badfinger posted this on 2/20, I tried it and it did not fix the throttle lag. I think it was also suggested to change the 3 seconds to 10 seconds. Except for the delay off idle, my 08 EGC runs great. I'll be watching closely for a real fix.
Quote:
Note
Whenever a new twist grip sensor (or ECM) is installed, place the engine run/stop switch in the RUN position and turn the ignition/light keyswitch to IGNITION and then back to OFF four times (without starting engine). Allow at least three seconds to elapse between ignition cycles. As the ECM uses the first four ignition cycles to establish the optimum idle speed, there may be initial performance problems if the procedure is not performed, such as high idle or hesitation when the throttle is opened.
Old 04-01-2008 | 06:52 PM
xcelr8's Avatar
xcelr8
The cables are a thing of the past........TBW is here to stay.
Quick Reply: Drive by wire?
