For those of you that installed the Road Tech MP3 player, how did you route the audio wire? If you have pictures of the routing you used could you include. Before I use the adhesive clips I want to check some other options. Thanks guys!
Run with the wires on handlebars into fairing, then tuck between inner fairing and lower, bring it out just under the radio and plug in. Be careful with the outside jacket, it will cut easily when you are trying to tuck it under. I have a picture of radio face and the wire coming out under the inner fairing but my computer tells me file is too large when I tried to load picture.
