air shocks
Old 04-01-2008, 11:57 AM
jannie's Avatar
jannie
jannie is offline
Stage III
Default air shocks
I have a hand bike pump, but I cannot get any air to enter the shock air valve. HD wants $48.00 for a tiny hand pump. They must have done something to the valve so you have to buy this from them. Does anybody know how I can get my Xcountry bicycle pump to work??? Thanks
Old 04-01-2008, 12:24 PM
NOVA06SG's Avatar
NOVA06SG
NOVA06SG is offline
Default RE: air shocks
Cant you just find a freind with a air compresor or gas station repair shop?
For 48.00 you can buy a small compresor from Harbor tools.
Old 04-01-2008, 12:27 PM
lil_gmac2's Avatar
lil_gmac2
lil_gmac2 is offline
I would check the lines first. Is it any pressure in the lines?
Old 04-01-2008, 12:29 PM
Jugg's Avatar
Jugg
Jugg is offline
Don't use compressed air. You could blow the shocks.
Old 04-01-2008, 12:40 PM
DZLDR's Avatar
DZLDR
DZLDR is offline
+1
if you use an air compressor, you better have a GOOD pressure regulator on it
better price out the cost of new shocks before you start trying to air them up without the proper tools.
you will find that 48 bucks is a hell of a lot cheaper than new shocks.
just my .02
ORIGINAL: Jugg
Old 04-01-2008, 12:44 PM
Crusher's Avatar
Crusher
Crusher is offline
I have the HD pump. It's expensive but works very well and is compact.
On a side note: There is a small black button on the bottom of the unit. I thought it was to release air if you desired. But when I push it, no air releases. Do I have a bad pump????
Old 04-01-2008, 12:46 PM
caddman's Avatar
caddman
caddman is offline
HD adjusts the valve short so that other pumps won't reacht the stem core. the pump is nice and compact (i bought one, and love it). if you try you may be able to change the possition of the valve to make it work with the bicycle pump.
caddman
Old 04-01-2008, 12:56 PM
Jim Dawson's Avatar
Jim Dawson
Jim Dawson is offline
ORIGINAL: Crusher
That bleed valve button releases a tiny amount of air each time you press it, not enough to show on the guage with one press. Press it repeatedly and it will adjust the pressure in small steps. That's why they call it a "micro bleed" valve. One of my better $35 purchases.
Old 04-01-2008, 01:02 PM
Mathews2's Avatar
Mathews2
Mathews2 is offline
ORIGINAL: Crusher
If you fully depress the button it will not release air, put just enough pressure on the button till you hear the air releasing.
Old 04-01-2008, 01:03 PM
ripper43's Avatar
ripper43
ripper43 is offline
$29.00 on ebay
I have a Harley one so I don't know how good these are.
Quick Reply: air shocks
