air shocks
RE: air shocks
I also had reservations about spending the $35 my dealer wanted for the HD pump, but the pressure is so low and each psi makes such a difference that the only way to get any true adjustment without doing any damage to the shocks is to have the right tool.
I first thought that I would be adding and bleeding air everytime I switched from solo to 2 up riding. I am very happy with the ride when I am solo and the shocks are set for 2-up riding. But then again, I don't bitch about every little detail like my passenger does.............
Dennis
Dennis
RE: air shocks
ORIGINAL: Mathews2
If you fully depress the button it will not release air, put just enough pressure on the button till you hear the air releasing.
RE: air shocks
I just went and bought an bicycle pump last night and found it wouldnt work with the valve stem. I did use my air compressor but I DO have a good regulator and turned it down to almost nothing then incressed pressure until the desired pressure was reached. 15 psi. My 14 year old just got a new bike pump!
RE: air shocks
I use a normal bicycle pump on my 2000 RKC. Works fine. For some reason, it sometimes takes a little extra effort/pressure to get started, but otherwise, no drama. Would never use a compressor etc for the reasons stated such as damage to shocks.
One disadvantage is that a bicycle pump is not a "no loss" pump, but it doesn't take long to figure out about how much pressure you lose detaching the pump.I then use a $5 no loss pressure gauge to check the pressure. I checked mine very regularly when I fist bought the bike and didn't lose much pressure - about 2-3 lbs over 2-3 months - and only in the rear, never in the front.
This works fine for me and I'll tell you that Idid get a fright whenI saw theprice of $72 ($Australian or $64 US) for that tiny little HD pump atthe local HD dealers!!
RE: air shocks
I just got in one of the air pumps that ripper43 showed a picture of. Ionlypaid 19.95 and got it from Midwest Motorcycle Supply, aka..Jireh Cycles. This pump works very well, appears to be sturdy, and is more compact than the HD pump. It is mostly metal and also has a bleeder button. Jireh stock # is 116-10.
