aging evo
RE: aging evo
Sounds like you got a good one. Of course the obvious stuff like make sure the drive belt is in good shape, battery, tires, make sure things are all adjusted as they should be. As you ride it you'll know if it's using oil, etc. If it pulls strong and runswell then you're good to go I dare say.
As always have a cell phone and AAA membership for your trips and you'll have no worries.
My '05 has 73,000 on it right now and has never run better.
RE: aging evo
Thank for the info, I am going to take it in and have the wheel bearing replaces with some good aftermarket bearings, I will do some research to see whats the best.. someone recommended the inner cam bearing to be replaced as the factory one is very weak, I will also ask the dealer, if they can pull all the work that HD has done to the bike, not sure if they can do such a thing, I was told this bike has had all the work done at the HD dealership where it came from... that will be helpful if I can get the list..
RE: aging evo
ORIGINAL: Hanoverfiste
RE: aging evo
Make sure and check that all the bolts and screws are tight. Also check your cables to make sure they are in good shape. I bought my 90 Heritage Classic about 6 months ago and it had not been ridden in about 5 years. I have had to replace quite a few items due to it sitting for so long. If yours has been ridden quite a bit the seller should have kept up with repairs, but it's always better to be safe than sorry. Also make sure the tires are in good shape. Also I would have them check your electrical items. I have replaced one of the battery cables and also have replaced the coil and ignition module. Just a very careful going over of the bike and have the shop give it a good look over and you should be in good shape.
RE: aging evo
No need for aftermarket wheel bearings. Slap new tires on wheels, balance themand repack the bearings you have, check the endplay per the manual and replace the seals. Easy to do and cheap.
Replace front and rear brake pads, bleed both brakes. Replace fork, tranny, primary and engine oils. Pull petcock from tank, clean and inspect/reassemble.Replace or recharge airfilter depending on what type you have. Replace and Gap sparkplugs, check wiring harness for any frayed, pinched or corroded wires/connectors.
Replace top and front motormount, cheap and easy to do. If you are not comfortable doing a lot of serious wrenching, have a shop replace the inner cam bearing with a torrington, both lifters and redo the base,head and rocker box gaskets if any are leaking.
Just did all of this on my buddies 90 eglide that he just picked up with 65k on it. Got it done with one long Saturday and a fewhours on some weeknights. We scoped it out and picked it up for 5k cash, after I put in the retro radio kit from biketronics he'll be in it for less than another 1k and we'll be ready for our Canada trip.
RE: aging evo
95 Evo with 144k on her. Runs fine but has been maintained religously. New cam and cam bearings, new lifters, adjustible push rods, new carb, coil, really just the usual amintenance items. Have your shop go over the bike really well and do what they say. Then ride her.
Bubba
Bubba
jo_mama
12-02-2011 06:25 AM
