Just did a tune
Just did a tune
I just did a fluid change, spark plug change, and I retuned my PCIII. I have always heard of the 0 throttle but I never did it. I was so impressed by the initial change from stock to pcIII that I didnt think the 0 throttle would make a difference. It does. There was always a slight sputter (very slight) when I took off, I thought it was just a Harley thing, but I did the 0 throttle and it went away, it runs much better. Just thought Id give my personal experience.
RE: Just did a tune
Setting your throttleposition is a must when installing a PCIII. Your throttle position is shown in % and if it is off at 0 throttle it will be off all the way through the rpm range. While in the PCIII software, with the bike hooked up and idling your throttle % should read 0. The PCIII map works from throttle % and rpm to give the map settings. A little off 0 and the whole map is a little off. Detailed instructions for setting can be found on the Power Commander web pages.
Ride Safe,
Mike
Ride Safe,
Mike
RE: Just did a tune
ORIGINAL: DiegoKing
What's 0 throttle? I have a slight sputter on take off and would LOVE to get rid of it.
http://fuelmotousa.com/SetThrottle.swf
Peter
