Xenon bulbs
Old 03-29-2008, 09:24 AM
malmax's Avatar
malmax
malmax is offline
Default Xenon bulbs
I am interested in swapping my stock headlight bulb with a xenon halogen. Any manaufactuers that are better than the other?
Old 03-29-2008, 09:40 AM
sifularson's Avatar
sifularson
sifularson is offline
Default RE: Xenon bulbs
I'm using PIAA.
Old 03-29-2008, 10:14 AM
cmhfguy's Avatar
cmhfguy
cmhfguy is offline
Not sure what your poll is asking... can you explain? Are you asking where to GET them? Where you BOUGHT them?
Old 03-29-2008, 11:25 AM
heywood727's Avatar
heywood727
heywood727 is offline
I put in HID's in the RG. Lots of light now.
http://s268.photobucket.com/albums/j...oject/?start=0
[IMG]local://upfiles/50578/1B5EEDAA747241E6B4968E1EBC9A4016.jpg[/IMG]
Got them from Here:
http://www.motorcyclemetal.com/
Old 03-29-2008, 11:48 AM
MustBBrent's Avatar
MustBBrent
MustBBrent is offline
Big difference between halogen and HID Xenon bulbs. HID requires a conversion. Blue, suposedly brighter halogens are a farse IMHO. Spend the money and get the HID kit. I did on my wife's car. I plan to on the scoot after my current couple of projects. If they ever end...
Old 08-24-2008, 04:38 PM
TexasSnake's Avatar
TexasSnake
TexasSnake is offline
Default Xsighting Lighting HID
I like Kuryaken/Xsigting Lighting's HID with the bullet shaped housing.
Easy to install, everything hidden inside the housing, just plug and play.
My first two were duds, but the last one has been on for almost a year now.
So bright its like having a frigging laser beam attached to the head of your shark!
Old 08-24-2008, 05:09 PM
bulldogmoe7's Avatar
bulldogmoe7
bulldogmoe7 is offline
HID there is no other
Old 08-24-2008, 05:19 PM
dansflhti's Avatar
dansflhti
dansflhti is offline
I'm wondering what the numbers are on the headlight bulb and the spotlights on a 2006 egs....are they 9003,9004,9005....etc?
Old 08-25-2008, 11:44 AM
bookworm's Avatar
bookworm
bookworm is offline
I switched from the stock lamp to a Philips MotoVision 9003(h4) lamp a few months ago and what a difference! Much brighter than stock. Will even light up some road signs on a shady road in the daytime and it is great at night.
I considered HID but couldn't justify the cost. The Philips lamp only cost ~$13 at Farm and Fleet (in Waukesha) and since you are in Wisconsin that should work for you. I would think that someone would have them online as well.
Now, if they would just make the 881 running light bulbs the same way I would really be set.
Old 08-25-2008, 01:25 PM
biz44's Avatar
biz44
biz44 is offline
For just a better quality replacment H-4 bulb, I always go with the Sylvania Silver Star bulbs. They will give you more hours of use than stock, and are brighter....noticeably so. I have had friends I ride with ask me when we stopped what type of headlight I am using because it seems so much brighter than theirs.
Just one thing though....NO MATTER what brand bulb (H-4) you go with, make 100% sure you wipe the glass envelope down with a clean tissue and rubbing alcohol. This will remove any dirt or finger prints that may have found their way onto the glass. If not removed before use, the heat produced will concentrate at the dirty spot and cause a failure. I am not sure if the Sylvania or any other brand bulb comes off the line all clean and stuff, but why take a chance? Just clean them all before use, and you will have no problem getting the maximum amount of usable hours out of any H-4.
Quick Reply: Xenon bulbs
