Clutch adjustment help. I SCREWED UP
Old 03-27-2008, 08:04 PM
Snowmobiler34's Avatar
Snowmobiler34
Snowmobiler34 is offline
1st Gear
Default RE: Clutch adjustment help. I SCREWED UP
When torquing nuts and bolts make sure what units you are to use ft.lbs (foot pounds) or in.lbs (inch pounds). 90in.lbs equals a little less than 1/2 ft.lbs. So if you tightened it to 7.5ft.lbs you torqued it 14 times the recomended amout. The click type torque wrenches usually work fine. Why spend $400 on a dial type. You will need two sizes to do everything on your bike.
Old 03-27-2008, 08:07 PM
Dalton's Avatar
Dalton
Dalton is offline
Release plate, pressure plate, it is called a lot of things. You can easily replace it. I would not try repairing it. Take a socket that fits the jamb nut, weld a nut on the end. The you can slide your allen wrench through it, hold the adjuster screwand tighten the jamb nut with a wrench until "snug"
ken thompson's Avatar
ken thompson
ken thompson is offline
The Schlong Man
Dawg - Adamec of Jacksonville on Baymeadows Rd.
Asuperheat - I did get the inch pounds too for $14.99 but it was 1/4" and I guess I dont have a 1/4" sockets. I should go get some.
Mandog's Avatar
Mandog
Mandog is offline
ORIGINAL: dawg
clutch release plate pn#37903-90 $14.50 retail....if that is what you fugged up. Tell me your dealer and I'll tell you if they have one in stock.
Damn your handy to have around
Old 03-27-2008, 08:12 PM
ken thompson
The Schlong Man
ORIGINAL: Dalton
Weld? I don't think I'll be welding anything anytime soon. Thanks though.
Old 03-27-2008, 08:15 PM
dawg's Avatar
dawg
dawg is offline
Received 3,239 Likes on 1,850 Posts
ORIGINAL: ken thompson
21 dealers in FL showing in stock....Adamec not one of them
Old 03-27-2008, 08:18 PM
ken thompson
The Schlong Man
It figures. Thanks for checking. Did you happen to check all three. there is Adamec of Regency and Adamec of Orange Park as well. Maybe they show separately.
Old 03-27-2008, 08:20 PM
stevepacman's Avatar
stevepacman
stevepacman is offline
Ken, sorry to hear about your saga Have you seen this maint. video before? Without this video I would have been lost doing my clutch adjust. Notice the guy doing the demo isn't using a torque wrench to tighten the jam-nut down. Only an allen driver to hold the adjuster screw and an open-end wrench to tighten the jam-nut (aka "jam-nut")
http://www.expertvillage.com/video-s...aintenance.htm
Old 03-27-2008, 08:22 PM
SG 1's Avatar
SG 1
SG 1 is offline
ORIGINAL: cwilks
This is exactly why its NOT necessary to Torque every freakin bolt and nut on your scoot
Good Luck
Exactly. Sometimes tight is tight.
Old 03-27-2008, 08:24 PM
biz44's Avatar
biz44
biz44 is offline
Hey ken....I know its a little late, and its not what you want to hear right now, but before you get started re assembling everything.....make sure you go out and buy a nice torque wrench. IIRC Matco sells a nice little set of two wrenches......both click type. One is a 1/4", and the other 3/8".....it would be a very good investment even if your only planning on light wrenching on your bike. Me personally I have 5 torque wrenches three from Snap-On, and that set from Matco......but I been turning wrenches on bikes since 1981.....I still want one of those digital read out units though.
If you look on ebay, you can find some real good deals on tools......I would just make sure to buy new on a torque wrench though....unless you have access to getting it calibrated cheaply.
Quick Reply: Clutch adjustment help. I SCREWED UP
