To Do or Not to Do?
RE: To Do or Not to Do?
..still got time,dont leave until the 23rd of April,so I should be alot closer anyway (I hope),let the dealer do the 1K then I'll do the rest,wanna make appointment..been so busy at work Ride time limited!![:@]....commute??...whats that?...about 25 yard's from front door of house to front door of office!!
ORIGINAL: Windup08
If you haven't done an oil change on it yet definitely do it before. You probably already have some metal shavings in the oil pan from the first few break in miles, plus the clutch cable tends to do most of its stretching in the first few hundred miles (at least mine did). If you are going to have the dealership do the service I would recommned doing it awhile before you take off on the trip, so you have a chance to ride it a little and check things over before taking off.
