Engine noise question
2000 Road King with 45k miles, fairly quiet mufflers. Cold startup sounds like a lifter noise if it were an older car. Quietsmostly after running a minute but still think it's there very lightly going down the hiway. Bike has windshield and wind deflectors so probably hearing all noises. Oil level full and less than 2000 mileson it. Cam chain tensioners were checked within the last 500 miles.
Is this normal for this engine?The 1200 Sportster that I had rattled like a sewing machine and never broke so not sure if this is right or I need to take it back into the dealer (boughtdealer warranty and they replace just about anything that shows wear at no cost). They had it for the cam chain tensioner check and replaced gears in the trans, primary and secondary gears and sprockets and rear sprocket and rear head gasket. All I payed for was the belt.Thinking maybe this is normal or they would have torn into that too? They must make money on this warranty. It's from a warranty company, not HD. I know when I was in the automotive business we could make decent money from these type of warranties as well.
Any thoughts?
Any thoughts?
RE: Engine noise question
Sounds like you have a lazy lifter. Wouldn't hurt to drop in a set. You could have one of the others that won't stay pumped up when hot and that may be what you are hearing. Everybodys perception of noise is differnet. All I will say is hydraulic lifters are suppose to be quite.
Ron
Ron
ORIGINAL: zzrider
I heard a noise resembling this on my EG and after explaining it to my mechanic he told me he thought I was hearing the fuel injecters. Maybe the same thing?
ORIGINAL: rbabos
Ron
Ron
Some noises are normal. You will always be able to hear the valves hitting their seats and things like that. This is constant uniform noise and normal.Can't tell if the sound you hear is normal over the internet but the lifter swap will at least cure the one that's noisy during startup.
Ron
Ron
