Reduced Effort Clutch Kit - DIY?????
RE: Reduced Effort Clutch Kit - DIY?????
Yep, new bike come this way.
Had no problems with the install.
Maybe others can comment - but I remember reading the the clutch plate could be installed without pulling the primary cover off - as I remember, you need to bend the spring plate a bit to squeeze out through the clutch cover opening.
Which brings up another question: why didn't the MoCo make the clutch opening such that you can pull the clutch out without removing the primary cover?
WOW - thanks for all the replies - sounds like a winner - and a cheap DIY'er.
Still don't have a clear picture though on the install - the entire primary cover must come off or just the clutch cover???
What's the deal with the exhaust - no need to pull off anything if you can go through the clutch cover???
And help me out, WTF is a "ramp"??? You have to change the lever too to put in this ramp???
It would beCOOL if someone had access to a scanner and put the install directions online here as a linked .pdf or pic???
Many of us would really appreciate that
THANKS
Dave H.
THANKS
Dave H.
ORIGINAL: dchoran
THANKS
Dave H.
THANKS
Dave H.
I dont know thats about the best I can describe it?????
I just wanted to know what a VPC is that SCRider talked about........Variable pull clutch....????
ORIGINAL: dchoran
THANKS
Dave H.
THANKS
Dave H.
I had to change out my clutch cable for my handlebar swap. On my '06 I had to drop the exhaust to get at the clutch cover. No way around it. Maybe someone here has found a better way. Anyway you just have to remove the clutch cover. I recommend that you roll the bike up onto a 2x6x8 to allow the bike to lean over further and you won't have to drain the tranny.
[IMG]local://upfiles/4575/87839AA649F6477C92F67F727F278126.jpg[/IMG]
The ramp is that 2 piece cast unit in the lower corner of the pic below. It sits in a recess inside the clutch cover and has 3 ball rearings sandwiched between the two halves. Your clutch cable will hook onto the end of the ramp and when you pull the cable the top half of the ramp assembly will pivot and roll on the ball bearings forcing the two halves apart and thus pushing against the clutch basket. You will need a pair of ring pliers to remove the snap ring holding the ramp in place. I recommend replacing the gasket although you might get away with reusing the old one. It really is a simple job. A manual helps.
[IMG]local://upfiles/4575/FB3016E28E254C3CA915ABF7B0228D58.jpg[/IMG]
After posting this, I went to my '06 service manual. The diaphram spring pictured above has to be installed on the clutch basket. This will involve removing the derby cover on the left side. This may be the extent of this or it could be more involved. I can't honestly say for sure because my scoot came with the new design. I am only familiar with the clutch cover disassembly on the right side. I believe someone earlier said something about just installing the ramp and not the spring. This may be why it wasn't done.
jtouchette
31
05-31-2006 09:46 PM
