AIM VP-008-92T
Old 03-26-2008, 11:40 PM
Biggzed's Avatar
Biggzed
Biggzed is offline
Default RE: AIM VP-008-92T
That doesn't seem right at all. This is using the HQ575 cams and HVP heads right? Have you checked compression since the build was finished?
Zach
Old 03-26-2008, 11:42 PM
CigarCritic's Avatar
CigarCritic
CigarCritic is offline
ORIGINAL: Biggzed
Zach
Post removed
Old 03-27-2008, 04:22 AM
Bryan TTM's Avatar
Bryan TTM
Bryan TTM is offline
bet youre losing some power thru the clutch....i run a 92T with spring and a Barnett clutch pac w extra plate....i'm bettin you'll see at least 110 with the new clutch
ORIGINAL: CigarCritic
ORIGINAL: PhilM
and you think it was fast before....
Say "byebye back tire!"
So, did Spike give ya some good advice on the motor?
Phil, I'm actually quite disappointed in the HQ 107 build. My numbers after 44 pulls today are only 98.99/109.69. Even if I were running a 2 into 1, I would not have reached what HQ states on their website site of 115+/120+. My two Tuners don't think so either. They said if I put the Fatcat back on I would be around 108/116. Tuner stated that the pipes were killing me but I knew I would take a hit but not this big.
On the other hand...the bike runs hard and the tune is perfect.....I wanted the advertised numbers and additional power as 98.99/109.69 is lacking what I had in mind for my bike. I laid out some serious cash for this build.
Any ideas or comments?
[IMG]local://upfiles/49160/779E4E0A9CFF40FEAE3685954C0C9A18.jpg[/IMG]
Old 03-27-2008, 08:00 AM
CigarCritic
ORIGINAL: Bryan TTM
Post removed
Old 03-27-2008, 08:47 AM
PhilM's Avatar
PhilM
PhilM is offline
I agree. That's not what it should be. My 98" tuned in better, with a PCIII.
I have not seen those pipes yet, but typically duals are better on the top - they are falling off in this case. Where it is happening is often caused by clutch slippage or running out feul (injector size, etc). The afr looks decent, so its "probably" not injectors.
Do you know for sure that they tuned timing as well as air/fuel?
If we can't figure this out, you may wanna call Kevin & get his input too.
Old 03-27-2008, 09:01 AM
CigarCritic
Post removed
Old 03-27-2008, 10:20 AM
PhilM's Avatar
PhilM
PhilM is offline
Do you have any experience in dealing with the public or customer service? I somehow doubt it.
I was gonna see if I could help you, but with an attitude like that, it's probably safe to say nothing will ever be good enough for you.
Best of luck to ya.
Old 03-27-2008, 11:02 AM
Harleypingman's Avatar
Harleypingman
Harleypingman is offline
CigarCritic--Are the same guys who tuned your bike the same guys who didn't know how to adjust a clutch???
Do yourself a favor and contact Kevin at HQ, then use the edit function to modify your earlier posts bitchin' about outcomes that are the result of your mechanic and tuner, notthe product.
Also, contact bigjohn1percenter as he has an HQ 107 that is very fast and has spoken to Kevin a good bit about getting the biked dialed in.
Frankly, if your tuner is mediocre, and he's out of answers as to why he can't get better numbers, you can expect him to say the package won't deliver the advertised numbers--he could do a 100 pulls, but not get it better if he isn't a good tuner.
Old 03-28-2008, 03:30 PM
CigarCritic
ORIGINAL: Harleypingman
You made that up as I never stated that.
Kevin has been contact...my post have been removed. Fatcat and dyno next week.
We will see what happens and I'll be looking for 110+/120+ as shown/told with a 2-1 pipe.
Big Dave
07-31-2019 09:45 AM
SG-Jay
11-05-2017 04:43 PM
dochawken
07-06-2014 10:38 PM
FX4
05-24-2014 09:51 AM
Raventhik
05-31-2010 03:29 PM
Quick Reply: AIM VP-008-92T
