Smart alarm Question
Im looking for some info on a HD smart alarm. My dad has a 03 road king and he had a alarm but i think he just got the speaker part for it. He wants to make it chirp when he arms it. He says there is a way to charge it back and forth. as in chirp, not chrip. So how would we go about doing this?
Thanks,
Josh
Thanks,
Josh
RE: Smart alarm Question
I am not sure about the Smart Alarm, but having the security system is just the start. You need to install the siren to get the chirp. I thought the older Smart alarms you had to but the siren and the pager transmitter seperate.
The Smart Alarm IIhas thesiren and transmitter are combined.
ORIGINAL: 1Harleyrdr
What is the radio shack part #????
$5.49
102dB Piezo Siren Model: 273-079| Catalog #: 273-079
Add some sound with our Piezo buzzer siren! Operates on 6-14 VDC, with 150mA Current at 12V. Buzzer ...
ORIGINAL: ArcticCat843
ok....He HAD the alarm already. He wanted it to chrip so he bought the smart siren for it. He put it on and it still doesnt chirp. He thinks there is just a setting you have to change to make it chirp.
As for your orginal question about rturning the chirp on and off.
Cycling quickly through two armings and disarmings will switch the system from either chripless mode of the chirp mode.
1. With the fob present, the ignition switch to IGNITION and the system disarmed, turn the ignition switch to OFF.
2. When the system arms (2 flashes of the turn signals), Immediately turn the ignition switch to IGNITION.
3. Wait until the security lamp goes out, then immediatley turn the ignition swith OFF.
4. When the system arms (2 flashes of the turn signals), immediately turn the ignition switch to IGNITION and wait for the system to disarm.
