Does this part exist?
Looking for a quick disconnect backrest kit for my 07 EGC. Currently have an 804-06 kit for my Tour Pack. Like to put a backrest on it for the OL. The one I got from the dealer last night only workswith an 803-06 kit. Difference between the kits is the 803 front docking points are about 2 inches forward. Looked through the catalog and online and can't find a thing....
sK
RE: Does this part exist?
Did see that after the fact. Question is, the chrome top rail cover that runs along the fender bracket, "U" shape on the fender, precludes putting a docking point in the front. Also the bracket on my 53303-07 kit (bolted to the underside of my TP) appears to be to short to mount to the front docking points...
Detachable Tour-Pak® Rack Kit 53303-07
Transform your Electra Glide® Classic model for around town cruising. This kit includes everything needed to convert the rigid-mount Tour-Pak® to an easy on-and-off detachable version. In just seconds (and without tools), you can install the Tour-Pak® for that long run across the country, and remove it for a stripped-down look when you get there. With the addition of Docking Hardware Kit P/N 53803-06 (sold separately), you can install a detachable Sissy Bar Upright and passenger backrest pad for around-town passenger comfort. Complete kit includes two-up docking hardware kit, detachable two-up Tour-Pak® Rack, chrome license plate holder, reflector, and AM/FM antenna relocation hardware.
ORIGINAL: ShortyK
That is the kit I got last night. The front docking point cut outs on the side supports is about 2 inches longer. I can see that I need front docking points, but if I install those, the TP docking points will be 2" short....[:@]
harleybill
03-07-2007 10:34 PM
