Push button fuel door
Old 03-08-2008 | 06:08 PM
1Harleyrdr's Avatar
1Harleyrdr
Default Push button fuel door
Ok this is the last thing I need to officially have too much crap laying on the basement floor.
Where did you get the keyless fuel door.
Old 03-08-2008 | 06:15 PM
UltraKla$$ic's Avatar
UltraKla$$ic
Default RE: Push button fuel door
I got the smooth top push button fuel release from my HD dealership. Best $20 bucks I've spent. No more digging for keys with each fuel-up.
Is this what you're asking?[&:]
Old 03-08-2008 | 06:19 PM
CREEPSHOW's Avatar
CREEPSHOW
ORIGINAL: UltraKla$$ic
+1
Old 03-08-2008 | 06:26 PM
1Harleyrdr's Avatar
1Harleyrdr
eggsactly. Hmm So the Dealer has them.
Thank you
Old 03-08-2008 | 06:33 PM
UltraKla$$ic
Found HERE
Guess what though? I don't think they fit '08's.[&:]
Old 03-08-2008 | 06:34 PM
Hinge's Avatar
Hinge
Last time I checked (about a month ago), H-Ddid not have the keyless one for 08's yet. A few folks on the forum have modified the other ones to work.
Old 03-08-2008 | 06:35 PM
Eddy G's Avatar
Eddy G
The thing I found with that set up is the little tin flap they use to open the door wears out and the door gets harder to spring open.
So what I did was get a small but firm spring about 1/4 to 3/8 of an inch and run one of the dash bolts though it. It works better then the metal clip thing.
I'll try and take and post a pic.
Old 03-08-2008 | 06:54 PM
1Harleyrdr's Avatar
1Harleyrdr
You are correct dont fit 08. Maybe some one has a nifty fix for it? I would rather not have to dig for a key
Old 03-08-2008 | 06:56 PM
electaRICK's Avatar
electaRICK
mine from my 07 did not work on my 08,
but lots of guys said it worked for them???
Old 03-08-2008 | 06:59 PM
HOGinit's Avatar
HOGinit
The smooth door came with the bike but on my O8 Ultra I obtained a push button latch assembly and just 5 min later had replaced the Key assembly with the push button, So even though they don't have the door yet your dealer should be able to get or have the push button assembly.
Quick Reply: Push button fuel door
