Rinehart Quiet Baffles
Has anyone installed the 2" quiet baffles in the true dual set up and noticed any difference in power loss or gain? How is the sound compared to the stock baffles? I had my cams changed to Andrews 37's and the rineharts are even louder than they were. Mine are the first generation mufflers that use 3 different size baffles 2" for quiet, 2 1/4 standard, and 2.5 performance. Just wondering if I will need to retune the sert with the smaller baffles. Thanks for your help.
RE: Rinehart Quiet Baffles
I'm running the quiet baffels in my 08 FLHX and I like them.Don't expect them to be too quiet though.I think Rinehart says 7 decibles less.They really help at highway speed when I'm trying to listen to my radio.Crank onthe throttle and it's still loud.My H-D dealership said they I would only loose a couple of horsepower so I think that their worth it.The only thing that I don't like about the baffels is that they take away some of the low rumble the pipes have at idle.Hope this helps!
Its funny that this post comes up now. I have just changed my rinehart baffles out from the standard 2 1/4" to the quiet 2" baffles.
In my opinion it made a big difference in the sound, alot quieter. Still has a nice rumble and has taken some of the higher pitch out.
My build is a 95" with the 37G cam heads done and the works. It made 98 horse and 104 torque with the standard baffles when I had
it dynoed after the build. My bike is in the shop getting dynoed as we speak. Should have numbers tommorow and the sheet by Saturaday.
I am planning on posting both sheets that way people can see the difference if any? Time will tell. I think the bike was running alittle richer
after the baffle change but I only put 30 miles on and decided just to take it in a see where it is and have the fine tuning done if needed.
Hope this helps
Hope this helps
