Strange Sound Coming From Rear When Off Throttle
Old 03-06-2008 | 04:16 PM
Motown_HOG's Avatar
Motown_HOG
Default Strange Sound Coming From Rear When Off Throttle
I recently had the dealer change my worn out stock rear tire with a new 150mm metz. Now I am getting an odd noise when I am off the throttle coming to a stop. The noise disappears when I pull the clutch lever in. Any ideas before I take it back to the dealer?
If it matters the dealer also changed the rear brake pads when he did the tire swap.
Old 03-06-2008 | 04:20 PM
The Baron's Avatar
The Baron
Default RE: Strange Sound Coming From Rear When Off Throttle
The belt may be deflecting into the tire and when you pull the clutch in it doesn't have any load on it and ceases with the deflecting bit.
Old 03-06-2008 | 04:23 PM
SoCal_Pappy's Avatar
SoCal_Pappy
Check you Final Drive Belt Cover\Guard on the inside & ck air pressure - Found mine rubbing on my '01 RKC - I ended up just removing the cover\guard
joeyvaz
09-28-2017 06:57 PM
Weitzel
04-25-2009 12:23 PM
cwickgo9
01-04-2009 03:09 PM
FFLETCHER
05-26-2008 11:33 PM
GreyGhost
03-17-2008 05:01 AM
Quick Reply: Strange Sound Coming From Rear When Off Throttle
