RK Classic Bag Locks
Just received my bag locks from Lock Your Leathers, they are a real class act. When the bag lids are locked the bags cannot be removed from the bike. Call or e-mail Cathy at 1-877-407-0739 or www.lockyourleathers.com:)
RE: RK Classic Bag Locks
I have a set of the same locks that i got last spring. I like them a lot just wish they had the same key as the ignition. It's nice not having to remove the bags when you stop for the night. Just a hint for the install. Instead of cutting the hole for the lock cycliner with a blade like the directions suggest use a 3/4" drill spade bit. The first lock took me about an hour and fifteen minutes to install cutting the hole with a blade then (Duh!) I used the spade bit and installed the second lock in about 10 minutes. And, the install was much cleaner. You can't see the first rough cut hole but I know it's there. [sm=goodidea.gif]
I wish Harley made a set. I don't want to change the emblem.
I found this manufacturer has them also - but they may be the same thing.
RKCl bag locks
RKCl bag locks
