Remapping not necessary
In the April issue of American Iron there is an article about bolting on 10 HP with an air cleaner change and mufflers. In the article they said with this change the ECM was capable of remapping on its own.
Does any body have any experience with this?
Would this only apply to the S&S system they were showcasing or would it work with any ac/muffler change?
BTW in the article also showed that the muffler change in this case did nothing for the HP but gave it a better sound. I'm sure different mufflers would have different results.
George.
George.
RE: Remapping not necessary
I'm not sure if I would buy into the idea that the ECM remaps on its own. I know that you can change mufflers without a remap but you most like will experience some discoloration on the right side pipe. Adding the air cleaner I feel you have to do something because you now have a far less restrictive air flow over stock and you are bound to experience some negative affects in doing so.
But hey I ain't no mechanic either. I know just enough to get by.
I agree with you George. Motorized vehicles made allot more sense to me before the computer chip was added and fuel injection.
What makes me mad is I feel the idle is too low on my Ultra however I can not adjusted without dinking with the mapping. I've taken it back to my dealer 3 times complaining about this after I had themdo a stage 1 mapwhen Iadded dual headers and air cleaner. Every time they dink with it and within a few blocks of the dealer it starts dropping down close to 800 rpm's when I pull up to a stop light. When it idles at 800 rpm's the damn thing will shake the fillings out of your teeth.
I added the Rush Pipes with 2" baffles and the AC setup to me 08 Ultra and didn't remap. I haven't had any issues at all, but I was told that if I go with bigger baflles, I would have to. A friend of mine has the Rush with 2.5" baffles and he gets some decel popping, so maybe what they told me was correct.
Remapping is not neccessary with some mufflers, those that are still somewhat restrictive. But as soon as you add any high flow filter or non restrictive/open muffler to it remappnig IS neccessary. Unless you dont mind running your motor at 16-17:1 and eventually melting it down from being to lean!
I have an '07 SG and have not remapped the ECU. I have a high air flow air cleaner and a set of Rush slipons with the 2.5" baffles. I have not noticed any change in performance, butthe sound is awesome!! I am still able to attain the correct back pressureand have nice deep throaty rumble.
Thanks,
JB
Thanks,
JB
ORIGINAL: BIGBADCANE
