heated jackets, liners, pants, etc. Any recommendations?
Old 03-03-2008, 11:17 AM
Dennydp's Avatar
Dennydp
Dennydp is offline
Default RE: heated jackets, liners, pants, etc. Any recommendations?
Gerbings are great,Ive had the set for 10 years.Only down side is you tend to ride when it is really cold,watch out for ice! If you can ride to Gerbings its a great putt.The Hood Canal area is a great ride,local for me too.
Old 03-03-2008, 12:10 PM
2003flhtci's Avatar
2003flhtci
2003flhtci is offline
Thank you everyone...just what I needed. Up to now I've gone with...silk longjohns, cotton pants/shirt, wool bicycle tights and wool sweater, and finally a layer of leather. It works, but not really as flexible a system as I want. Being able to dial in a temp is going to be great. This really simplifies the process. I'll just go and get Gerbings.
Old 03-03-2008, 12:25 PM
gunnert's Avatar
gunnert
gunnert is offline
I ride year round, commute 105 miles a day into DC. I'd recommend the heated jacket over the vest. First, it is warmer and second it has the plugs at the end of the sleeves for gloves. You want the jacket to fit snug against your shirt, so you should try it on before you buy one.
I don't wear heated pants, legs are ok with overpants for an hour or two. If I was going to ride longer I'd buy the pants too. For gloves I'd go with the Warm N Safe insulated gloves. I sold my Gerbings/HD gloves on EBAY as soon as I got a pair of the Warm N Safe. These gloves aren't as cumbersome as the Gerbings and have greater heat output (they are also cheaper than Gerbings) The Warm N Safe dual thermostat is a better designed unit.
Old 03-03-2008, 12:27 PM
turtleman57's Avatar
turtleman57
turtleman57 is offline
One word and only one word needed GERBING http://www.gerbing.com/
Old 03-03-2008, 12:51 PM
gunnert's Avatar
gunnert
gunnert is offline
Turtleman56, I was like you, thought only Gerbings was the way to go. Until I tried Warm N Safe (gloves and thermostat)... I'm totally happy with the Gerbings Jacket liner. The Gerbing gloves don't produce the heat the Warm... gloves do. That is why I changed, got tired of being cold when the temp was below freezing.
Old 03-03-2008, 01:51 PM
moorefun's Avatar
moorefun
moorefun is offline
I have the gerbings pants and jacket liners. They are great. I had the gloves and switched to the warm and safe. They are much better gloves IMO. They are also cheaper.
Old 03-03-2008, 08:30 PM
NCCopBikeRider's Avatar
NCCopBikeRider
NCCopBikeRider is offline
Powerlet makes a great jacket liner as well as gloves.
Gerbings has just released a glove liner that can be worn under the next size larger all weather gloves, for the same warm hands and less bulk.
Be certain to get the controller for the ability to set the temperature to one that works for you.
Good Luck
Old 03-03-2008, 08:36 PM
electaRICK's Avatar
electaRICK
electaRICK is offline
as far as pants,,, I recomend fleece lined Carharts,,,, they are warm!
Old 03-03-2008, 09:05 PM
hardav23's Avatar
hardav23
hardav23 is offline
Are the Gerbings chest size conversions good or do you have to buy 1 size less? Just thinking about ordering one but don't want to order too big or small.
Old 03-03-2008, 09:12 PM
Green1340's Avatar
Green1340
Green1340 is offline
Hardav23, Check with the local Honda shops. A lot of them stock Gerbings, so go and try them on there and then order online.
Quick Reply: heated jackets, liners, pants, etc. Any recommendations?
