rear running light as brake light?
RE: rear running light as brake light?
Dont have one of these installed,but have always wondered how difficult it would be to put in myself http://www.heavycycles.com/product_i...products_id=27
i used this led strip--http://*******.com/287uea
and ran the wires under the fender up to the taillight. [following the stock wire routing].
the strip has wires for ground/running/brake.
the taillight on my eg had an open spot in the plug thatlit the brake light.
plugged it in and works like a charm...
good idea
You could easily make it one or the other.
I would think you need a run/turn module from HD or Kurykyn to start with as they give the turn/running light capability you are after. Then you would have to experiment a little to get your fender light into the same circuit. The run/turn lightsmay bedual filament though (probably not) and the fender light is not.
I bet it can be done with some time to study.
moondog99
08-12-2010 08:06 PM
lawnmower man
01-04-2010 02:02 PM
