Craftsman aluminum jack any good???
Anyone have experience with this particular jack on an 05 Ultra or similar??? On sale from $169 to $139 - good deal??? Stable???
THANKS Dave H.
Craftsman Professional 1500 lb. Motorcycle/ATV Jack
Sears item #00950191000 Mfr. model #AG02883G
Lightweight aluminum construction- weights only 44 lbs.; Low profile 3-1/2 inch clearance extends up to 19 (with Adapter Bars). Ideal for oil changes, tune-ups, clean-ups and more. Can be used as a dolly to move vehicle to convenient location for work or storage. Four position locking mechanism engages at 7, 11, 13-3/4, and 15. Rubber padded saddles resist vehicle slipping.
[IMG]local://upfiles/5166/53F7F5B0AB424CEF80D1688EBEA262F2.jpg[/IMG]
THANKS Dave H.
RE: Craftsman aluminum jack any good???
GET A HARLEY JACK. IT IS TWICE AS EXPENSIVE BUT FOOL PROOF. IT IS A GEAR DRIVE HAND JACK THAT WILL ONLY MOVE IF YOU CRANK IT UNLIKE THE HYDRAULIC ONE PICTURED. i CANNOT UNDERSTAND WHY ONE WOULD SPEND 20,OOO.OO PLUS AND THENCONSIDER SOMETHING OBVIOUSLY INFERIOR.
I have the craftsman aluminum. I'm very happy with it as it does what I need. It's low profile slides under my 05 Ultra while it's on the jiffy stand. It's easy to use. I can raise the whole scoot but I generally only do one wheel at a time. It's fine for me as I don't need to go high. Don't think I'd feel comforatble taking it all the way up.
If I wanted to take it way up I'd buy a Pitbull air lift.
I own this one and use it all the time for my Road King. It works great, very stable and easy to use. It has around 4 different height settings to lock in on and the handle removes easily for when you're working on the bike. In no way is this an inferior jack. I recommend it.
I think it is a great jack. I don't have a problem with lowering the jack which is what I believe the first responce seems leery of..........
Search around on the forums. This one is definitely preferred over the 80.00 Sears jack. Some guys had drift down issues with those.
I considered both the Sears aluminum jack and the Harley jack. I decided against both of them because of the lack of a foot pump. I feel much more comfortable holding on to the bike's handlebars with both hands while pumping a foot pump, especially during the critical transition phase when the bike is going to and from the jack. I got a Pit Bull and I love it. It will lift my Street Glide and Gold Wing up to 24" high with rock solid stability. I strongly recommend that you consider a jack with a foot pump.
Doug
Doug
