Radio Shack Siren
RE: Radio Shack Siren
I just installed mine yesterday. Your correct the low tone on the 079 for the "set" beep. I am not minding that, personallyas it is not obnoxious to me and will not be to others each time I step away from the bike. But when you trip the alarm all hell breaks loose! That said I am wondering if I can find a correct connector to mate it up. For now,I have my wires jammed into the identifiedsockets and slid the plug back into the blank carefully with the wires feeding into the appropriate contact points. But longterm, I would rather find the other side of the connector for it to mate up. You would think you could find that connector end, at aNapa Autoparts storeorthe likeas it looks like a Automotive style plug. The next quest for me in a very cheap upgrade, even with a price of a connector to solder the beeper wiresto, and would make it less of a backyard upgrade with more reliable longtermcontacts.
Anyone yet identify theneededplug style/name/or part number?
ORIGINAL: binkman78
I bought the #273-079 for my '03 but the arm/disarm "beep" was real weak - went back an bought the #273-070 (2 tone w/warble) $12.00. Now it make some noise.........[sm=happy046.gif]
there is on on the left side it has a black wire green with a stripe and I think it's either gray or light purple lighting was not good??????
But the install in here said the black,green and brown wire I don't see a brown wire???
ORIGINAL: Duracell
Yep, It's on the left side. It plugged into a blank plastic holder. It should only have 3 wires in it. Don't use the 4 wire connector next to it that one goes to the ECU for connecting the SERT.
ORIGINAL: binkman78
George.
ORIGINAL: rsofa
ORIGINAL: Duracell
rangemaster
08-19-2012 07:49 AM
