Audio Upgrades
Old 03-01-2008 | 07:43 PM
Eddy G's Avatar
Eddy G
Default Audio Upgrades
Completed a few Audio Upgrades this weekend and wanted to share them.
Head unit Sony CDX-81 w/usb
Hog tunes in the fairing. Those I put in last summer.
Now I added a Pyle marine amp. Mounted it right on top of the radio. I had to use a band saw to cut it down a little but it fit pretty good and tied down with some tie wraps.
I had bought some glove boxes for my lowers off of e-bay and with a dremil tool and some hardware I converted them to speaker boxes.
I got a set of Polk audio db461 marine rated speakers and used the bench grinder and dremil to trim them to fit the glove boxes. Packed in a little insulation to help hold the sound.
The speakers didn't come with grills so I had some old speaker hardware that I adjusted and fit.
Then I got a little creative. I had some HD badges I took off of an old pair of boots so I epoxied them to the grills for a custom look.
The system sounds awesome. I'm really excited about it and can't wait to hit the road this spring.
Please excuse the dirty bike. The tanks off for some other mods I'm doing but I wanted to add what pictures I did have.
Later
[IMG]local://upfiles/44089/0F04FBB6801D4BF5B8A95C5BEC3CF268.jpg[/IMG]
[IMG]local://upfiles/44089/ACC295A1B7EA463EAF8859EFB0257196.jpg[/IMG]
[IMG]local://upfiles/44089/EAC05369F440457187AB7150F545063F.jpg[/IMG]
Old 03-01-2008 | 07:54 PM
Drifting Texas's Avatar
Drifting Texas
Default RE: Audio Upgrades
If you can ride you might as well work on it. Looks like you're being quite creative.
Old 03-01-2008 | 08:13 PM
leohd's Avatar
leohd
real nice job, if your still bored you can do mine too
Old 03-01-2008 | 08:18 PM
CREEPSHOW's Avatar
CREEPSHOW
Looks good! Did you install the stereo with the biketronics kit for your controls?
IceHeritage's Avatar
IceHeritage
ORIGINAL: Eddy G
Later
What did you use to control the Head Unit? what is the Wattage on the Amp? 2channel or 4?
Looks Good
Thank You
Old 03-01-2008 | 08:41 PM
Eddy G's Avatar
Eddy G
Oh ya, I forgot the Biketronics kit.
I bought the Sony on line
The amp is 2 channel 240 Watts. I only have it wired to the lower Poke speakers.
The hog tunes sound pretty good on their own.
Is it possible to wire the 4 speakers to a 2 channel amp?
Old 03-01-2008 | 09:00 PM
skltr's Avatar
skltr
Nice mod, you did a great job!!!!
Old 03-01-2008 | 09:33 PM
Abnmarine's Avatar
Abnmarine
ORIGINAL: Eddy G
Yes you can. If your speakers are 4 ohm then it will run the amp in a 2 ohm load.
Old 03-01-2008 | 09:42 PM
Eddy G's Avatar
Eddy G
ORIGINAL: Abnmarine
ORIGINAL: Eddy G
Which is why it has a high and a low level input? It's wired in to the low input now.
Do you think it would be worth adding the hog tunes to the amp?
Old 03-02-2008 | 05:19 PM
modes's Avatar
modes
ORIGINAL: Eddy G
ORIGINAL: Abnmarine
ORIGINAL: Eddy G
The different inputs are for situations like putting an amp in a car with a the stock head unit that has no rca outputs to hook up to for the signal. If you had two sets of 8 ohm speakers hooked up to a 2 channel amp the load would be 4 ohm, the amp would create less heat and put out less power (speakers will sound less loud), Not all amps are 2 ohm stabile, but should be clearly labeled what ohm load they are stabile down to.
Adam
Adam
apetterez
08-05-2016 12:28 PM
MontyCop05
Audio Systems
09-24-2015 01:02 PM
toddhowudoing
Audio Systems
02-12-2015 06:58 AM
BrianCash
Audio Systems
02-16-2014 08:07 PM
Quick Reply: Audio Upgrades
