Has anyone installed the replacement 3 LED lightson the lower part of the rear fender that work as a running light and a brake light ? Any difficultly on the install, tips.
Thanks,
capt42a
Yes its very easy. Unplug the old one from the wireing harness. Then unbolt the wholefacisa.Saddle bags have to come off to do this.Three nuts on each side. Thenyou have two screws holding in the led running light in place.Bolt it back up and plug the new one to the harness.
With a little patience and agilityit can be removed without removing anything else but the 2 screws holding it into the fender. That is how I did mine. Helps light things up when stopping.....always a good thing.
I think it is a great addition. The install was a little bit of a pain as I have the rear docking hardware. Still not to big of a deal with a little patience.
N2DWIND, StreetGlide2006, and SMUNDORF,
Thanks for the reply's, I'll probably do the mod this coming weekend, unless it's nice enough to do some riding.
capt42a
