Tour Pack
Tour Pack
For those of you that have detachable tourpacks.....Where and how do you store it when it is off the bike? Seems like every time I take mine off, it manages to recieve a minor blemish from just laying around! Does anyone know of a wayor abracket that allows for the tour pack to be mounted on a wall, up out of the way?
Thanks
Tobster
Thanks
Tobster
RE: Tour Pack
Get on ebaymotors and go into harley accessories. I got mine for around eighty bucks, but there's a couple of ones on there for less.
Mine holds all detachables and windshield, was also a neat rack to put your hard bags without scuffing them up when your cleaning bike, etc.
BigDaddy2
06 EG Standard
Been ridin since 1967
BigDaddy2
06 EG Standard
RE: Tour Pack
Here is the one I purchased back in December. I have a leather tour pack. This rack is heavy gauge steel with a black powdercoat finish.
http://www.haulenass.com/detachable_...ies_wall_mount
I think they had it on sale for the holidays, but $159.00 is cheap insurance for $800 tour pack with hardware. I do not have any pictures, but it was easy to mount to the studs in the garage.
RE: Tour Pack
Here ya go....I used 3/8 threaded rod......nuts/washers......and 3/8 (inside diameter) plastic tubing......nailed the 2x4's to the wall and drilled the holes thru the 2 by's....measure the distance between the mount slots on the detachable stuff and make it that wide....make sure you drill as far away from the wall (on the 2 by or use 2 together to space it from the wall)
[IMG]local://upfiles/13719/4F23B721E0654FD783EDF0461228739D.jpg[/IMG]
[IMG]local://upfiles/13719/8D9CDAA6A0B249FEADD44D7CD79E3510.jpg[/IMG]
[IMG]local://upfiles/13719/1A93E14A42324ECEA1427383B2400A66.jpg[/IMG]
Guest
Posts: n/a
RE: Tour Pack
ORIGINAL: cwilks
Here ya go....I used 1/2 threaded rod......1/2 nuts........and 1/2 plastic tubing......nailed the 2x4's to the wall and drilled the holes thru the 2 by's....measure the distance between the mount slots on the de-tachable stuff and make it that wide....make sure you drill as far away from the wall (on the 2 by or use 2 together to space it from the wall)
