I'm going to purchase the above mentioned item to match my billet heel/toe shift levers. How is the install??? Since I don't have my bike at home yet could someone describe the install? Thanks!!!!
Remove the set screw, wiggle off the arm taking note of its angle (reomove the floorboard for clearance if necessary), slip on new arm, check clearnces during shifting motion and boot fitment under peg, install setscrew, transfer shifter peg or install aftermarket peg of choice.
Let me ask you this......Are you running stock headers, or do you run duals? Reason I ask is this ........I do not know if this is true or not, but i heard from the stealer that if you have duals (in my case V&H's) you will not be able to have the extended billet brake lever. Apparently, the pipes will interfere with the lever.
AGAIN, I DO NOT KNOW IF THIS IS A TRUE STATEMENT, BUT I'M JUST GIVING YOU A HEADS UP!!!
