dyno # from 88 cubes
Old 02-26-2008, 09:53 AM
schoney's Avatar
schoney
schoney is offline
Default dyno # from 88 cubes
I am interested in seeing dyno numbers from baggerz with 88 cubes only. Please post your dynoed HP & TQ, along with what you did and who did it. I have a 99 king FLHPI with an88 TC and want to build it next year. My old evo (80 ci) dynoed 85 with a good build, but not radical. I am not interested in 95, 103, 110, or larger ci, only 88 TC #'s. There is a lot of potential in these TC's, they are good motors.
Currently I have a pclll, open intake and home built exhausts, motor is otherwise stock. 72 HP and 79TQ at about 4000 RPM.
Thanks in advance.
Old 02-26-2008, 09:57 AM
fxdwg_rugby's Avatar
fxdwg_rugby
fxdwg_rugby is offline
Default RE: dyno # from 88 cubes
Pictures of the pipes on your scooter?
[sm=ttiwwp.gif]
Old 02-26-2008, 10:12 AM
schoney's Avatar
schoney
schoney is offline
I sent them in to the paint shop, hopeing to get them back in a couple of weeks. I took the stock exhausts cut them off just behind the rear mount and ground off the welds and punched out the baffles. When I put them back on the bike they sounded like a Yamaha on steroids, so I went to the local tractor supply and bought an 80 chain sprocket just large enough to weld inside my muffler. My thinking was the inner diameter hole was large and exhaust could also escape along the outside of the sprocket, but there wasenough metal there to change the tone of the exhaust. Put it back on the bike and I loved the sound. I rewelded the end of the muffler back on, but instead of the turnout pointing down it now points 100 degrees to the outside away from the hard bags.
Old 02-26-2008, 10:19 AM
FLHT's Avatar
FLHT
FLHT is offline
You can see my numbers in my Sig. Stock 88 except for A/C, exhaust and PCIII.
Old 02-26-2008, 10:42 AM
Superglide 04's Avatar
Superglide 04
Superglide 04 is offline
Check the sig.
Old 02-26-2008, 12:04 PM
schoney's Avatar
schoney
schoney is offline
superglide what rpms are you that high, their good #'s for intake exhaust and sert only.
Old 02-26-2008, 12:11 PM
CREEPSHOW's Avatar
CREEPSHOW
CREEPSHOW is offline
Superglide 04and FLHTbasically have the same mods but such a huge difference in numbers, why is that?
Old 02-26-2008, 03:47 PM
Neckball's Avatar
Neckball
Neckball is offline
Rinehart True Duals
Fullsac True Duals
I'm guessing this would have an effect on the peak numbers.
Old 02-26-2008, 03:48 PM
bobbyg12's Avatar
bobbyg12
bobbyg12 is offline
My info:
2006 FLHTCI 88"
SE Stage 1 kit
SERT
25 degree injectors & d/l
80463 HD Catalyst touring mufflers
SE TC 88 Hi Compression 1450 pistons (9.5:1)
SE 211 Cam
85 ft-lbs peak @ 4000 rpm
82 hp peak @ 6000 rpm
Very smooth performance compared to stock...
Done by American HD in Ann Arbor, MI
Seem to be having trouble uploading pix today...[:@]
An error occurred processing the page you requested.
Please see the details below for more information.
[align=center]
Program File Name
/uploadpro.asp
COM Error Number
-2146825284 (0x800A0BBC)
Error File Name
/js/PGDUpload.asp
Line Number
558
Brief Description
Write to file failed.[/align]
_uacct = "UA-939292-2";
urchinTracker();
Old 02-26-2008, 04:22 PM
FLHT's Avatar
FLHT
FLHT is offline
ORIGINAL: Neckball
Rinehart True Duals
Fullsac True Duals
Great question.....Do you think just the different head pipes would make that much of a difference?
Here is a sheet can somebody explain the big difference in our numbers
Quick Reply: dyno # from 88 cubes
