Notices
Tie-down straps recommendation?
Old 02-25-2008, 06:29 PM
toastedoat's Avatar
toastedoat
toastedoat is offline
Default Tie-down straps recommendation?
I searched all of the forums, but couldn't find anything with any of the keywords I could think of, so my apologies if I missed one and this is a double-post - just bought a Kendon trailer and wanted to know if anyone had any recommendations for the tie-down straps, both which manufacturer and whether to use ratcheting, cam-lock, or a combo of both? How do you know a good quality tie-down - I'm not super concerned about price, it is close to $20k I am strapping with these, so I'll spend the extra $$ to make sure it gets there in one piece...
Sean
2007 FLHTCU
2003 FLHRCi
2003 FLSTCi
Old 02-25-2008, 06:35 PM
bigheadted's Avatar
bigheadted
bigheadted is offline
Default RE: Tie-down straps recommendation?
I do not have any info on brands but will say even if using good ones I would and do use two per side as a extra bit od insurance. Had one fail and darn happy I had them doubled.
Old 02-25-2008, 06:45 PM
mrsr71's Avatar
mrsr71
mrsr71 is offline
Use nothing but these. They're the best money can buy.
Old 02-25-2008, 06:58 PM
DKSS07's Avatar
DKSS07
DKSS07 is offline
ORIGINAL: mrsr71
Ditto. Heard a lot of good things about them.
Old 02-25-2008, 07:42 PM
soos's Avatar
soos
soos is offline
Regardless of which manufacturers strap you go with, do choose a ratchet style. Cam locks are absolutely useless.
Old 02-25-2008, 08:33 PM
NICK56's Avatar
NICK56
NICK56 is offline
WWW.MRPRODUCTS.COM BEST MONEY CAN BUY.. USED EM TFOR 20 YEARS... NEVER A BRAKE!
PS: ONLY BUY RATCHET TYPE TYPE TIE DOWNS..
Old 02-25-2008, 08:44 PM
BirchwhiteHD's Avatar
BirchwhiteHD
BirchwhiteHD is offline
"Use nothing but these. They're the best money can buy".
I'm told these are very good quaility
Old 02-25-2008, 08:47 PM
Rodent's Avatar
Rodent
Rodent is offline
I also have the MRPRODUCTS Power Classic Ratchet straps. No problems what so ever and they don't cost an arm and a leg.
Don't forget the SOFT TIES if the straps you get don't have the built in soft loop end.
Old 02-25-2008, 09:06 PM
skltr's Avatar
skltr
skltr is offline
+1 on the Powertye.
Old 02-26-2008, 12:55 AM
acftdr's Avatar
acftdr
acftdr is offline
Ditto the ratchet style ties. Also keep an eye out for the load limit. You should be looking at the WLL "working load limit", which should be around 1000 pounds. The ultimate break should be about 3 times that. ANCRA makes excellent products. For some good info go to:
http://www.trailer-parts-forless.com...cycle_ties.htm
http://www.easternmarine.com/em_store/tiedowns/
You've got the right idea, you don't want to skimp. Another thing folks don't think about or realize is that it's one thing to have an 800 pound bike tied down static (not in motion). It's a whole 'nother animal when you're braking and accelerating, factoring the "g" forces which can easily turn your 800 pounds into thousands of pounds momentarily. Think about what the seat belt in your vehicle is made of, and how much weight it's working with. I think your bike weighs a lot more than you do, so your tie down should be that much more beefy.
[sm=smiley16.gif]
Quick Reply: Tie-down straps recommendation?
