oil spitting out of a/c
I know this thread has been on before but I thought I would throw it out again to see if there were any new ideas. On an 07 Ultra with the Arlen Ness Big Sucka a/c I am getting oil coming out of the filter after long rides. Very annoying and messy to say the least. What is the permanent fix? I mentioned this to the dealer over the weekend and the first thing he said was so you have a high flow air filter and asked if the bike had the proper amount of oil. The answer was yes to both and he implied that I woiuld have to live with it. On my 02 Ultra with stock filtration I road to Milwaukee and back from the Northeast and did not have a drop of oil weep from the filter. I need to admit that I did have the oil a little high on the stick when this first happened and corrected the level as well as cleaned the filter but it returned on the next 300 mile ride. I have also read about the umbrella valves in the top of the engine inside the rocker covers. Is it possible that the one time that I over filled they lost there seal and need to be replaced? As the new riding season approaches I would love to get this mess cleared up all help would be appreciated.
RE: oil spitting out of a/c
I found this little article interesting (yeah, it's Sportster-related but still interesting):
http://www.mklsportster.com/xloilblowbyarticle.htm
I talked with Ness last week on the phone as I just ordered and received a new stage 1 Big Sucker. My backing plate looks different from the one posted above. My breather holes are located outside the throat of the plate and are much smaller. There are two "rain gutter" looking channels, one below each hole going into the throat. Ness said they redesigned the backing plate with the smaller holes, outside the throat with the rain gutter deals because people were still having blowby problems with the old backing plate. I have mine installed, but have not had a chance to try it yet as my bike is down for paint and wheels.
Lenny, which type of backing plate do you have?
If I still get carryover problems with the new Big Sucker, I;m either going to drill and tap some fittings as per Dawg or order a SE chrome backing plate and go back to the SE black rubber tubes that point straight into the throat. Hopefully I can still use my Big Sucker stage one filter and Ness billet cover with the SE chrome backing plate...
I have a FLHRS with Carb. I get this blow-by oil leak after running 65 or70 mph for an extended time.This problem only showed up after I switched to Mobil V-Twin. It's not too much oil as I've changed it twice and it still does it. I'm keeping the Mobil oil it seems to quiet the lifters down. I'll just wipe it down and ride.
Crankcase vent used to be at the bottom on old models way back when and I believe this was used to oil the chain at one time if I remember correctly. Anyways after it was moved to the top of the cyclinder head the problem wasn't there till people started installing SE backing plates or open filters. The oil escapes the air filter and leaks down the side when the stock filter used to trap it inside the air cleaner. Either you live with it, run the stock setup, or reroute the vent! I don't like the idea of pumping oil threw my carb/TB or filling my air filter with oil restricting it so I choose to run it down out of the way similar to Dawgs. This is one reasonI chose not to go with the Ness setup. I think alot of Ness's products are looks first then function.
I seen a guy one time with regular bolts in where the vent is and freaking oil was coming out of the gaskets and around the bolts, idiots.
Dawg, are you running a filter on the end of the hose or did you leave it open?
