i have a 2000 FLHTCI and I am trying to do the 18" swap. I have a 150 mm avon on there right now and i have a small rub on the belt (even with guard removed). Should i go with a pully spacer? or a 140mm rear tire?
also, right now with the wheel on, there doesnt seem to be enough room for another spacer -- is anything removed? or is it just a REALLY tight fit?
the 105mm avon is on the 18" wheel. Very slight rub. I called a local bike parts store (only domestic parts) and they had the pully spacer. Just over 1/8th inch thick. We are trying that now. It should work perfectly -- i just want to make sure that i dont tweak the belt too much.
