5th Gear Whine/Clatter
Old 02-25-2008 | 11:33 AM
albertasaurus's Avatar
albertasaurus
Default RE: 5th Gear Whine/Clatter
ORIGINAL: Mr_Bill
You didn't mention how many miles you have on the bike. The more miles you put on the better it will run and the tranny noise will get better. 1000 mile check up you could switch to a heavier Syn tranny fluid and this will help. Your last resort is the IDS upgrade, that should do it for you.
Regards,
Mr_Bill
Only have 2400 km (1500 mi) on it so far. Eventually, I'd like to put wide whitewall tires on it so I may go the IDS route when I do the tire change. For now, I'll make sure to have the noise checked every time it's in for service so it gets documented.
As for changing tranny fluid, how does this affect warranty? Something tells me if I put non-HD fluid in and something blows up, the mothership is going to say the warranty is null and void.
Old 02-25-2008 | 11:55 AM
Harleynole's Avatar
Harleynole
What is the cost of the IDS upgrade??
Old 02-25-2008 | 12:03 PM
carpetride's Avatar
carpetride
ORIGINAL: albertasaurus
ORIGINAL: Mr_Bill
Regards,
Mr_Bill
Come on, you're kiddin right?
As long as you don't runit dry, what's Harley gonna do, send a sample of your tranny fluid to a lab?Use Mobil 75/ 90 synthetic, it's much better than the dog **** Harley puts in
Old 02-25-2008 | 05:22 PM
txfxstrider's Avatar
txfxstrider
Using other than Harley fluids will not void your warranty. However, there is nothing wrong with the Harley oils. People have favorite oils and tend to get emotional about it but it is just like people arguing about which beer is better. It does not matter, it is just a matter of choice. Change the fluids when the manual specifies and you will be fine. I have been using Harley dino oil since 1973 and never changed the fluids more often than recommended and never had an oil related problem. Just saying.
Old 02-25-2008 | 06:50 PM
pittguy's Avatar
pittguy
Choo yes the odds were in favor of a noisey one early on but it still happened later on,couldve been early models with late sales.This so called -never heard noise- had the MoCo trying various things to try to pinpoint the cause.They finally got something that worked.
Old 02-25-2008 | 06:59 PM
hoosierhog88's Avatar
hoosierhog88
The '08's have IDS stock. Smoothest riding machine I've ever owned.
Just order one through Zanotti's and get 'er done! You'll be glad you did!
Old 02-25-2008 | 07:41 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
07 ultra here hevier syn will quiet the whine ids did take care of the clatter and seems to let me run a little lower rpm without luggin (thats just what the butt dyno tells me). ids does make for quiter smoother ride all the way around.
Old 02-25-2008 | 07:49 PM
bob2002's Avatar
bob2002
I tried every oil out there and until theIDS my bike sounded like a piece ofcrap in 5th gear,the IDS cured the clatter and the whine is mostly gone. GO FOR IT!
Old 02-25-2008 | 07:50 PM
Xtreme Hawg's Avatar
Xtreme Hawg
ORIGINAL: nmfxstc
This is an Ultra? Hey...no problemo! TURN THE STEREO UP! No more tanny gear noise! Simple, huh?
[sm=exactly.gif]
Old 02-25-2008 | 07:58 PM
SteveB FLH's Avatar
SteveB FLH
Just remember syn3 is a MOTOR OIL not a transmission oil... use a good 75w90 or higher rated synthetic GEAR OIL....IMHO...The transmission will quiet down...IDS is also good .
Quick Reply: 5th Gear Whine/Clatter
