08 SG shocks on a 07 RK Police?
Old 02-24-2008 | 11:08 PM
TN_Lowrider's Avatar
TN_Lowrider
Default 08 SG shocks on a 07 RK Police?
I'm looking tolooking to use 08 SG rear shocks on my 07 RK Police. Since we can't use the search feature, I figured I'd ask. Can I throw stock length 07 or 08 SG rear shocks on my 07 FLHP? According to Progressive,FLHRs are 13" shocks and according to HD.com lowering shocks "won't lower FHLRCs or FLHXs." My thinking says the SGs are 12" thus, lowering my skoot about 1". Any input would be appreciated.
Potter
Old 02-24-2008 | 11:27 PM
JonnyD's Avatar
JonnyD
Default RE: 08 SG shocks on a 07 RK Police?
FLHX and FLHRS came with the lowered shocks. FLHRC came with standard. I put the Profile shocks on mine and it helped. I would say the shocks are the same, maybe not internally but the length. Either buy a good set of used FLHX/FLHRS shocks from someone who took care in plugging them when taking them off or buy the profile lowering shocks and get em from Zannoti's for 20% off.
Old 02-25-2008 | 06:28 AM
Pastor John's Avatar
Pastor John
I did the same thing you are talking about - put Street Glide shocks on my '07 Road King. They fit perfectly, and gave a good slammed appearance. The reduced travel became noticeable when travelling two-up as they would bottom out unless I put 25 lbs of air in them, and then they were a bit harsh. But overall, I thought they were a good option since I was looking for the appearance improvement and mostly ride solo.
Old 02-25-2008 | 09:53 AM
TN_Lowrider
Thanks guys.
Pastor John - You're situation is exactly like mine. I ride solo mostly, but do plan on weekend trips with the Mrs who's a huge HD fan. I wanted to keep the stock pneumatic set-up because I'm not a fan of lowering kits which "can" create added stress on the frame. I see guys around town who ride two up quite oftenon lowered SGs. Figured if they can lower 'em even more why couldn't a RK get lowered to their stock set up?[sm=confused06.gif] I thought about trying Progressives but past experience has shown themto bepretty harsh, especially two up. You wouldn't happen to have a part number for the SGs do you?
Old 02-25-2008 | 10:14 AM
Jazz56's Avatar
Jazz56
I also just put stock SG shocks on my RKC. Easy to do. I posted an ad in the want to buy section here and bought a used pair from a forum member. You should try it. Don't buy new. Good luck
Old 02-25-2008 | 10:21 AM
JonnyD's Avatar
JonnyD
54662-02A FLHX shocks
$140 Chicago H-D
$126.68 Zannoti's H-D
54631-02B Profile lowering shocks
$220.76 Chicago H-D
$216.64 Zannoti's H-D
So this tells me that maybe the profile shocks are valved differently and are a step up from stock. I rode two up with mine for a few hours after install and never bottomed once with only 10# in them. Very happy with the Profile shocks.
Old 02-25-2008 | 12:35 PM
TN_Lowrider
Thanks JohnnyD. Those were my thoughts as well. So would you say your Profiles have a firmer ride than stock?
Old 02-25-2008 | 12:59 PM
bigtone's Avatar
bigtone
I think that the price difference is because the price is for one shock for the FLHX, where the low profile comes as a set of 2. The standard 13 inch air shock goes for around $140 each.
Old 02-25-2008 | 05:15 PM
JonnyD's Avatar
JonnyD
ORIGINAL: TN_Lowrider
"Bigtone" may be right on that......You may want to check. I don't notice any difference as of yet. So far so good, but I'm sure it matters on your weight and the weight of your pass., luggage, etc. Just be sure if you buy used, you can trust they were plugged and stored properly and no oil was lost.
dyoungblood357
09-27-2017 11:00 AM
TracerBullet
11-17-2013 09:55 PM
rick
03-27-2009 11:55 PM
TN_Lowrider
02-25-2008 01:49 PM
gordo 2050
11-05-2007 04:45 PM
Quick Reply: 08 SG shocks on a 07 RK Police?
