what is the cure for the high speed wobble???
Old 02-25-2008, 05:24 AM
rocknrod's Avatar
rocknrod
rocknrod is offline
Default RE: what is the cure for the high speed wobble???
ORIGINAL: rcastorena
I really don't think mine wobbles??? I've pushed it pretty hard on some 80 mph curves and it's pretty damn stable.. Maybe if I hit a bump halfway through the curve it's not very nice but other than that, I think it handles better than my previous 04 Roadstar 1700!
I have not seen the wobble either. Go figure.
Old 02-25-2008, 05:45 AM
bobmurdy's Avatar
bobmurdy
bobmurdy is offline
Hi Bud, I do a lot of miles (1200) to Portugal and back, every other month. I have been concerned at the wobbly back end on my Glide Standard (2006) since I bought it (owned a Road King and Heritage before). I purchased a St8 stabaliser and noticed a dramatic change in the handling. Best money I think I have spent on the bike to date, trust me its going to cost you a lot more in nerves and damages if you dont bother to fit one (Harley should fit one as standard). Hope this helps . Bob
Old 02-25-2008, 07:30 AM
Badfinger's Avatar
Badfinger
Badfinger is offline
BeforeI would buy anything to "add on" I would address the problem. It sounds like this issue occurs when one or more things are off. Loose or warn neck bearings, warn bushings, bike alignment, wheel warp or balance, suspension either shocks or springs, damper oil levels, tires, etc.
If the bike didn't exhibit these issueswhen it was newerit should be returned or rebuilt to its originalcondition. I would do thisbefore throwing money at the aftermarket fixes and putting them on abike that may only mask a serious condition. That could be a really disaster.
Ride well,
Jim
Old 02-25-2008, 07:37 AM
backnasaddle's Avatar
backnasaddle
backnasaddle is offline
So far I've been pretty stable on the '05, even when loaded but, yeah, you hit a good bump in a high speed sweeper and it WILL get your attention [:-]
Old 02-25-2008, 08:22 AM
NICK56's Avatar
NICK56
NICK56 is offline
IF THE MCY IS "HEAVY" ENUFF THEY WILL ALL WOBBLE. 2 UP ITLL WOBBLE.. LOTSA BAGGAGE ITLL WOBBLE.. THE ITEMS YOU MENTIONED MAY WORK.. IF NOT BUY A GOLD WING.. HATE TO SAY IT EVER LOOK AT A GOLD WING FRAME. HD WAKE UP.. PS: I WILL ONLY RIDE HARLEYS
Old 02-25-2008, 08:32 AM
Arizona's Avatar
Arizona
Arizona is offline
Never experienced that with mine, but i don't really do those high speed sweepers - very mellow cruising-type of rider here - so perhaps that's why.
Old 02-25-2008, 05:56 PM
gunnert's Avatar
gunnert
gunnert is offline
2003FLHPI, you are 100% correct, SLOW DOWN!!!! All the other stuff may "help", it won't cure.
Old 02-25-2008, 06:01 PM
sanaga's Avatar
sanaga
sanaga is offline
no...high speed wobble when leancant cured...slow down or change to GW or jap bikes.....
Old 02-25-2008, 06:02 PM
gunnert's Avatar
gunnert
gunnert is offline
Ed, I don't mean to dispute you, but there is no such thing as being able to handle/control a high speed wobble. All you can do is get out of the throttle and hold on, and, oh yea, say a little prayer. It's a sham Harley's are so prone to this pheno... My RT is more stable the faster I ride it, the Harleys are just the opposite.
Old 02-25-2008, 06:10 PM
bigheadted's Avatar
bigheadted
bigheadted is offline
To all you who say slow down, that is your OPINION, fact is there is indeed a handling defeciency with these chassis, just because your riding style or particular riding has not experienced it does not mean it does not exist. If you just cruise down the road mellow you will likely never have this happen but if you ride with more "spirit" you just might. Have any of you ever ridden a machine before and after the install of any of these products to make a resemblance of a qualified or knowing opinion ??? If I had listened to you folks and not those who have true experience regarding this I would not have ever made the upgrade that in my humble opinion made a very noticable improvement in the handling traits of my machine and the way I ride it. To those wondering about it do a lot of research, ask a lot of questions and wade your way through all the opinions of the unknowing and make your decision for you and your machine and the way you ride it. Now the can of worms is opened let the slamming begin !!! Look at the year of the bike the man is on, a 2008 just how worn could it be ?? Good advice to check and verify everything and ensure all is correct, I did and I still got the wag but only when riding hard in corners, gone now with the help of a aftermarket band-aid !!!
Quick Reply: what is the cure for the high speed wobble???
