Shifting
Old 02-25-2008 | 06:57 AM
DaveMK's Avatar
DaveMK
Default RE: Shifting
I changed the oil in my primary yesterday. I always had the dealership do it before.The manual clearly states "32" ounces. "Do not overfill". So why did I drain 38 ounces? Neutral is a lot easier to find now with 32 ounces.
With the money the dealership charges, you would think they could get it right. This isn't the only example of poor workmanship from this service dept.
Old 02-25-2008 | 07:43 AM
1flhtk4me's Avatar
1flhtk4me
ORIGINAL: DaveMK
I you read the service manual and the owners manual ('06 touring)they state to add 32 oz or to the bottom of the clutch spring.To get the level to the bottom of the clutch spring,this could be another 4-6 oz.
Some people just put in 1 qt., others like me add the extra.
My bike shifts fine with the higher level.
Other things to check for smoother shifting is.....primary and clutch adjustment and clutch cable for free operation.Lube the clutch cable.
Old 02-25-2008 | 08:47 AM
DaveMK's Avatar
DaveMK
My 02 service manual doesnt give the option of 32 oz "or to the bottom of the clutch spring". But it does say overfilling may cause difficulty in finding neutral at engine idle.
Old 02-25-2008 | 09:32 AM
Big Peter's Avatar
Big Peter
ORIGINAL: Bigtwin
Has anyone ever experenced what I call stiff or stubborn shifting. When the bike is cold it seems to shift fine but when the bike warms up it is sometimes hard to shift into neutral when I am stoped. any suggestions?
When my bike is cold, it's very hard to shift into 2nd gear.
Think I'll take SoCal Pappy's advise and use a good syn oil
Peter
bonesmutley
Shovelhead
08-12-2013 11:34 AM
fastalkintn
09-14-2012 06:51 PM
Tompop
07-08-2012 06:48 PM
Darkhorse08
09-28-2011 08:27 PM
62pan
05-11-2011 10:48 PM
Quick Reply: Shifting
